Jon,
Turns out beagle was not properly up and circumstantial evidence
indicates it was causing the issue that seems now to be resolved (see
quoted mesg from beagle admins below).
Could you try it again and report back what you get.
Ketan
The five Beagle storage nodes were found offline this morning. These nodes provide DSL, GPFS, and NFS via DVS to compute nodes throughout the system. These nodes have been rebooted and the jobs are running through the scheduler as expected. We are continuing to investigate why the storage nodes went offline, but users may resume running their jobs at this time
On 6/5/11 8:17 PM, Jonathan S Monette wrote:
> So you are seeing the same problem?
> On Sun, Jun 5, 2011 at 8:13 PM, ketan <ketancmaheshwari at gmail.com
> <mailto:ketancmaheshwari at gmail.com>> wrote:
> I do not know the reason why you are getting this. The PBS submit
> throws the following stderr:
> aprun: Apid 327667: Caught signal Terminated, sending to application
> Also on my another swift submission I am getting this as PBS
> submit stderr:
> [NID 00065] 2011-06-05 19:34:26 distributeControlMsg: Apid 327688
> write failure to node 66, 10.128.0.67, port 607, Connection reset
> by peer
> I suspect the last maintenance/upgrade of Beagle might have caused
> this.
> Ketan
> On 6/5/11 1:35 PM, Jonathan S Monette wrote:
>> I still have problems running this script. I does not seem to
>> ever execute. I get this to stdout
>> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog
>> modified locally)
>> RunID: 20110604-2338-5eik2hbb
>> Progress:
>> Progress: Submitted:1
>> Canceling job 173155.sdb
>> Canceling job 173182.sdb
>> I had to C-c the run. I would check qstat and it would say the
>> job was executing in the development queue but it seems like it
>> never ran. Also it seems that the coasters job was cancelled
>> twice during the Swift execution.
>> On Sat, Jun 4, 2011 at 1:12 PM, Jonathan S Monette
>> <jonmon at utexas.edu <mailto:jonmon at utexas.edu>> wrote:
>> Ok. Thanks. and the (none) also appeared when I was on
>> login1.beagle.ci.uchicago.edu
>> <http://login1.beagle.ci.uchicago.edu>. Thanks Ketan.
>> On Sat, Jun 4, 2011 at 1:09 PM, ketan
>> Yes, you should bring this to the attention of beagle
>> sysadmins.
>> On 6/4/11 1:01 PM, Jonathan S Monette wrote:
>>> Ok. I have my job submitted and it is currently waiting
>>> in the queue. besides manually resetting this variable
>>> everytime I am on beagle what else can be done? Is this
>>> something that I should bring to the attention of the
>>> sys admins for beagle?
>>> On Sat, Jun 4, 2011 at 12:51 PM, Ketan Maheshwari
>>> Alright, so this is the issue. GLOBUS_HOSTNAME is
>>> picked up from HOSTNAME and I do not know where does
>>> this none comes in your case.
>>> In my case I get hostname:
>>> login2.beagle.ci.uchicago.edu
>>> <http://login2.beagle.ci.uchicago.edu>
>>> see if you can manually change this env variable and
>>> try to run again.
>>> On Sat, Jun 4, 2011 at 12:49 PM, Jonathan S Monette
>>> login2.beagle.ci.uchicago.edu.(none)
>>> when you ran your test was in on login1 or login2?
>>> On Sat, Jun 4, 2011 at 12:47 PM, Ketan
>>> Maheshwari <ketancmaheshwari at gmail.com
>>> What does
>>> echo $HOSTNAME give?
>>> On Sat, Jun 4, 2011 at 12:44 PM, Jonathan S
>>> Monette <jonmon at utexas.edu
>>> I am not sure why that (none) appears.
>>> Is this a variable that the system sets
>>> or do I need to set it?
>>> On Sat, Jun 4, 2011 at 12:39 PM, Ketan
>>> This suprises me because, I do not
>>> see that (none) in my commandline.
>>> On Sat, Jun 4, 2011 at 12:38 PM,
>>> Jonathan S Monette
>>> I added
>>> echo ${OPTIONS}
>>> echo ${COG_OPTS}
>>> echo ${LOCALCLASSPATH}
>>> echo ${EXEC}
>>> echo ${CMDLINE}
>>> to the script. It seems in the
>>> $OPTIONS variable this appears.
>>> -Xmx8192M
>>> -Djava.endorsed.dirs=/home/jonmon/Library/Swift/swift-0.92/bin/../lib/endorsed
>>> -DUID=1881
>>> -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>> -DCOG_INSTALL_PATH=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>> -Dswift.home=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>> -Djava.security.egd=file:///dev/urandom
>>> There is the line
>>> I believe that is the
>>> parenthesis that is causing this
>>> to fail. Now How do I fix it.
>>> On Sat, Jun 4, 2011 at 12:36 PM,
>>> Jonathan S Monette
>>> I may have found the error.
>>> I download 0.92 binaries
>>> and changed the swift
>>> command script. I added
>>> On Sat, Jun 4, 2011 at 12:26
>>> wrote:
>>> Same result. Same error
>>> 12:24 PM, ketan
>>> wrote:
>>> can you try running
>>> the commandline by
>>> copying from run.sh
>>> and pasting it at
>>> the prompt.
>>> On 6/4/11 12:18 PM,
>>> Jonathan S Monette
>>> wrote:
>>>> I do have that
>>>> project. I did
>>>> projects --avail
>>>> and got back
>>>> Project PI
>>>> Title
>>>> CI-CCR000013
>>>> Michael Wilde
>>>> The Swift
>>>> Parallel Scripting
>>>> System
>>>> Here is my run.sh
>>>> file. I execute
>>>> with ./run.sh after
>>>> I did chmod +x run.sh
>>>> #!/bin/bash
>>>> swift -config cf
>>>> -tc.file tc
>>>> -sites.file
>>>> beagle-coaster.xml
>>>> catsn.swift -n=1
>>>> I do have sh and
>>>> cat in my path. I
>>>> can execute them.
>>>> Here is what which
>>>> sh and which cat
>>>> produced.
>>>> sh is /usr/bin/sh
>>>> cat is /bin/cat
>>>> On Sat, Jun 4, 2011
>>>> at 12:10 PM, ketan
>>>> wrote:
>>>> Can you try
>>>> "projects
>>>> --avail"
>>>> command on
>>>> beagle to see
>>>> if you are
>>>> member of a
>>>> project.
>>>> Else you will
>>>> need to request
>>>> membership. You
>>>> can do this
>>>> from this page:
>>>> http://pads.ci.uchicago.edu/access/
>>>> In any case,
>>>> your error does
>>>> not seem to be
>>>> because of the
>>>> above. Looks
>>>> like '(' has
>>>> sneaked in
>>>> because of some
>>>> unexpected typo
>>>> in commandline
>>>> .. can you
>>>> doublecheck it.
>>>> Also can you
>>>> make sure that
>>>> you have all
>>>> the files: tc,
>>>> beagle-coasters.xml
>>>> cf in PATH, ie.
>>>> are you able to
>>>> access them w/o ./
>>>> On 6/4/11 12:03
>>>> PM, Jonathan S
>>>> Monette wrote:
>>>>> I did change
>>>>> the work
>>>>> directory. I
>>>>> however did
>>>>> not change the
>>>>> project name.
>>>>> I do not know
>>>>> my project
>>>>> name so I kept
>>>>> the same
>>>>> project that
>>>>> was in there.
>>>>> Here is my
>>>>> modified
>>>>> beagle-coasters.xml
>>>>> <config>
>>>>> <pool
>>>>> handle="pbs">
>>>>> <execution
>>>>> provider="coaster"
>>>>> jobmanager="local:pbs"/>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="project">CI-CCR000013</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="ppn">24:cray:pack</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="workersPerNode">24</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="maxTime">1000</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="slots">1</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="nodeGranularity">1</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="maxNodes">1</profile>
>>>>> <profile
>>>>> namespace="karajan"
>>>>> key="jobThrottle">.63</profile>
>>>>> <profile
>>>>> namespace="karajan"
>>>>> key="initialScore">10000</profile>
>>>>> <filesystem
>>>>> provider="local"/>
>>>>> <workdirectory
>>>>> >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>>> </pool>
>>>>> </config>
>>>>> On Sat, Jun 4,
>>>>> 2011 at 12:00
>>>>> PM, Ketan
>>>>> Maheshwari
>>>>> wrote:
>>>>> Jon,
>>>>> Thanks for
>>>>> trying out
>>>>> catsn on
>>>>> Beagle.
>>>>> I just
>>>>> tried it
>>>>> myself but
>>>>> could not
>>>>> reproduce
>>>>> the error
>>>>> you are
>>>>> getting.
>>>>> Have you
>>>>> made the
>>>>> changes
>>>>> that are
>>>>> mentioned
>>>>> in the README:
>>>>> Change
>>>>> workdir
>>>>> location
>>>>> in
>>>>> beagle-coaster.xml
>>>>> Change the
>>>>> project
>>>>> entry in
>>>>> the
>>>>> beagle-coaster.xml
>>>>> to your
>>>>> project name
>>>>> Ketan
>>>>> On Sat,
>>>>> Jun 4,
>>>>> 2011 at
>>>>> 11:50 AM,
>>>>> Jonathan S
>>>>> Monette
>>>>> wrote:
>>>>> Hello,
>>>>> I
>>>>> am
>>>>> trying
>>>>> to run
>>>>> the
>>>>> catsn
>>>>> test
>>>>> on
>>>>> beagle
>>>>> using
>>>>> the
>>>>> files
>>>>> in
>>>>> ~ketan/catsn.
>>>>> I
>>>>> have
>>>>> copied
>>>>> over
>>>>> this
>>>>> directory
>>>>> over
>>>>> to my
>>>>> home
>>>>> directory
>>>>> and I
>>>>> believe I
>>>>> set it
>>>>> up
>>>>> correctly.
>>>>> I did
>>>>> module
>>>>> load
>>>>> swift
>>>>> and
>>>>> the
>>>>> ran
>>>>> run.sh
>>>>> that
>>>>> was in
>>>>> this
>>>>> directory.
>>>>> I get
>>>>> this
>>>>> error.
>>>>> /soft/swift/0.92/bin/swift:
>>>>> eval:
>>>>> line
>>>>> 152:
>>>>> syntax
>>>>> error
>>>>> near
>>>>> unexpected
>>>>> token `('
>>>>> eval:
>>>>> line
>>>>> 152:
>>>>> `java
>>>>> -Xmx8192M
>>>>> -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>>>>> -DUID=1881
>>>>> -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>>> -Dswift.home=/soft/swift/0.92/bin/..
>>>>> -classpath
>>>>> /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>>> vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>>> e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>>> .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>>> /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>>> org.griphyn.vdl.karajan.Loader
>>>>> '-config'
>>>>> 'cf'
>>>>> '-tc.file'
>>>>> 'tc'
>>>>> '-sites.file'
>>>>> 'beagle-coaster.xml'
>>>>> 'catsn.swift'
>>>>> '-n=1''
>>>>> I
>>>>> there
>>>>> something
>>>>> else I
>>>>> need
>>>>> to
>>>>> load
>>>>> on
>>>>> beagle
>>>>> to
>>>>> make
>>>>> swift
>>>>> run
>>>>> accordingly?
>>>>> Any
>>>>> intelligent
>>>>> fool
>>>>> can
>>>>> make
>>>>> things
>>>>> bigger
>>>>> and
>>>>> more
>>>>> complex...
>>>>> It
>>>>> takes
>>>>> a
>>>>> touch
>>>>> of
>>>>> genius
>>>>> - and
>>>>> a lot
>>>>> of
>>>>> courage to
>>>>> move
>>>>> in the
>>>>> opposite
>>>>> direction.
>>>>> Albert
>>>>> Einstein
>>>>> Any
>>>>> intelligent
>>>>> fool can make
>>>>> things bigger
>>>>> and more
>>>>> complex... It
>>>>> takes a touch
>>>>> of genius -
>>>>> and a lot of
>>>>> courage to
>>>>> move in the
>>>>> opposite
>>>>> direction.
>>>>> - Albert Einstein
>>>> Any intelligent
>>>> fool can make
>>>> things bigger and
>>>> more complex... It
>>>> takes a touch of
>>>> genius - and a lot
>>>> of courage to move
>>>> in the opposite
>>>> direction.
>>>> - Albert Einstein
>>> Any intelligent fool can
>>> make things bigger and
>>> more complex... It takes
>>> a touch of genius - and
>>> a lot of courage to move
>>> in the opposite direction.
>>> - Albert Einstein
>>> make things bigger and more
>>> complex... It takes a touch
>>> of genius - and a lot of
>>> courage to move in the
>>> opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make
>>> complex... It takes a touch of
>>> genius - and a lot of courage to
>>> move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things
>>> bigger and more complex... It takes a
>>> touch of genius - and a lot of courage
>>> to move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things bigger and
>>> more complex... It takes a touch of genius - and
>>> a lot of courage to move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things bigger and more
>>> complex... It takes a touch of genius - and a lot of
>>> - Albert Einstein
>> complex... It takes a touch of genius - and a lot of courage
>> - Albert Einstein
>> Any intelligent fool can make things bigger and more complex...
>> It takes a touch of genius - and a lot of courage to move in the
>> opposite direction.
>> - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110606/cbf2d523/attachment.html>
