yes.
On 6/5/11 8:17 PM, Jonathan S Monette wrote:
> So you are seeing the same problem?
> On Sun, Jun 5, 2011 at 8:13 PM, ketan <ketancmaheshwari at gmail.com
> <mailto:ketancmaheshwari at gmail.com>> wrote:
> I do not know the reason why you are getting this. The PBS submit
> throws the following stderr:
> aprun: Apid 327667: Caught signal Terminated, sending to application
> Also on my another swift submission I am getting this as PBS
> submit stderr:
> [NID 00065] 2011-06-05 19:34:26 distributeControlMsg: Apid 327688
> write failure to node 66, 10.128.0.67, port 607, Connection reset
> by peer
> I suspect the last maintenance/upgrade of Beagle might have caused
> this.
> Ketan
> On 6/5/11 1:35 PM, Jonathan S Monette wrote:
>> I still have problems running this script. I does not seem to
>> ever execute. I get this to stdout
>> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog
>> modified locally)
>> RunID: 20110604-2338-5eik2hbb
>> Progress:
>> Progress: Submitted:1
>> Canceling job 173155.sdb
>> Canceling job 173182.sdb
>> I had to C-c the run. I would check qstat and it would say the
>> job was executing in the development queue but it seems like it
>> never ran. Also it seems that the coasters job was cancelled
>> twice during the Swift execution.
>> On Sat, Jun 4, 2011 at 1:12 PM, Jonathan S Monette
>> <jonmon at utexas.edu <mailto:jonmon at utexas.edu>> wrote:
>> Ok. Thanks. and the (none) also appeared when I was on
>> login1.beagle.ci.uchicago.edu
>> <http://login1.beagle.ci.uchicago.edu>. Thanks Ketan.
>> On Sat, Jun 4, 2011 at 1:09 PM, ketan
>> Yes, you should bring this to the attention of beagle
>> sysadmins.
>> On 6/4/11 1:01 PM, Jonathan S Monette wrote:
>>> Ok. I have my job submitted and it is currently waiting
>>> in the queue. besides manually resetting this variable
>>> everytime I am on beagle what else can be done? Is this
>>> something that I should bring to the attention of the
>>> sys admins for beagle?
>>> On Sat, Jun 4, 2011 at 12:51 PM, Ketan Maheshwari
>>> Alright, so this is the issue. GLOBUS_HOSTNAME is
>>> picked up from HOSTNAME and I do not know where does
>>> this none comes in your case.
>>> In my case I get hostname:
>>> login2.beagle.ci.uchicago.edu
>>> <http://login2.beagle.ci.uchicago.edu>
>>> see if you can manually change this env variable and
>>> try to run again.
>>> On Sat, Jun 4, 2011 at 12:49 PM, Jonathan S Monette
>>> login2.beagle.ci.uchicago.edu.(none)
>>> when you ran your test was in on login1 or login2?
>>> On Sat, Jun 4, 2011 at 12:47 PM, Ketan
>>> Maheshwari <ketancmaheshwari at gmail.com
>>> What does
>>> echo $HOSTNAME give?
>>> On Sat, Jun 4, 2011 at 12:44 PM, Jonathan S
>>> Monette <jonmon at utexas.edu
>>> I am not sure why that (none) appears.
>>> Is this a variable that the system sets
>>> or do I need to set it?
>>> On Sat, Jun 4, 2011 at 12:39 PM, Ketan
>>> This suprises me because, I do not
>>> see that (none) in my commandline.
>>> On Sat, Jun 4, 2011 at 12:38 PM,
>>> Jonathan S Monette
>>> I added
>>> echo ${OPTIONS}
>>> echo ${COG_OPTS}
>>> echo ${LOCALCLASSPATH}
>>> echo ${EXEC}
>>> echo ${CMDLINE}
>>> to the script. It seems in the
>>> $OPTIONS variable this appears.
>>> -Xmx8192M
>>> -Djava.endorsed.dirs=/home/jonmon/Library/Swift/swift-0.92/bin/../lib/endorsed
>>> -DUID=1881
>>> -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>> -DCOG_INSTALL_PATH=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>> -Dswift.home=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>> -Djava.security.egd=file:///dev/urandom
>>> There is the line
>>> I believe that is the
>>> parenthesis that is causing this
>>> to fail. Now How do I fix it.
>>> On Sat, Jun 4, 2011 at 12:36 PM,
>>> Jonathan S Monette
>>> I may have found the error.
>>> I download 0.92 binaries
>>> and changed the swift
>>> command script. I added
>>> On Sat, Jun 4, 2011 at 12:26
>>> wrote:
>>> Same result. Same error
>>> 12:24 PM, ketan
>>> wrote:
>>> can you try running
>>> the commandline by
>>> copying from run.sh
>>> and pasting it at
>>> the prompt.
>>> On 6/4/11 12:18 PM,
>>> Jonathan S Monette
>>> wrote:
>>>> I do have that
>>>> project. I did
>>>> projects --avail
>>>> and got back
>>>> Project PI
>>>> Title
>>>> CI-CCR000013
>>>> Michael Wilde
>>>> The Swift
>>>> Parallel Scripting
>>>> System
>>>> Here is my run.sh
>>>> file. I execute
>>>> with ./run.sh after
>>>> I did chmod +x run.sh
>>>> #!/bin/bash
>>>> swift -config cf
>>>> -tc.file tc
>>>> -sites.file
>>>> beagle-coaster.xml
>>>> catsn.swift -n=1
>>>> I do have sh and
>>>> cat in my path. I
>>>> can execute them.
>>>> Here is what which
>>>> sh and which cat
>>>> produced.
>>>> sh is /usr/bin/sh
>>>> cat is /bin/cat
>>>> On Sat, Jun 4, 2011
>>>> at 12:10 PM, ketan
>>>> wrote:
>>>> Can you try
>>>> "projects
>>>> --avail"
>>>> command on
>>>> beagle to see
>>>> if you are
>>>> member of a
>>>> project.
>>>> Else you will
>>>> need to request
>>>> membership. You
>>>> can do this
>>>> from this page:
>>>> http://pads.ci.uchicago.edu/access/
>>>> In any case,
>>>> your error does
>>>> not seem to be
>>>> because of the
>>>> above. Looks
>>>> like '(' has
>>>> sneaked in
>>>> because of some
>>>> unexpected typo
>>>> in commandline
>>>> .. can you
>>>> doublecheck it.
>>>> Also can you
>>>> make sure that
>>>> you have all
>>>> the files: tc,
>>>> beagle-coasters.xml
>>>> cf in PATH, ie.
>>>> are you able to
>>>> access them w/o ./
>>>> On 6/4/11 12:03
>>>> PM, Jonathan S
>>>> Monette wrote:
>>>>> I did change
>>>>> the work
>>>>> directory. I
>>>>> however did
>>>>> not change the
>>>>> project name.
>>>>> I do not know
>>>>> my project
>>>>> name so I kept
>>>>> the same
>>>>> project that
>>>>> was in there.
>>>>> Here is my
>>>>> modified
>>>>> beagle-coasters.xml
>>>>> <config>
>>>>> <pool
>>>>> handle="pbs">
>>>>> <execution
>>>>> provider="coaster"
>>>>> jobmanager="local:pbs"/>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="project">CI-CCR000013</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="ppn">24:cray:pack</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="workersPerNode">24</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="maxTime">1000</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="slots">1</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="nodeGranularity">1</profile>
>>>>> <profile
>>>>> namespace="globus"
>>>>> key="maxNodes">1</profile>
>>>>> <profile
>>>>> namespace="karajan"
>>>>> key="jobThrottle">.63</profile>
>>>>> <profile
>>>>> namespace="karajan"
>>>>> key="initialScore">10000</profile>
>>>>> <filesystem
>>>>> provider="local"/>
>>>>> <workdirectory
>>>>> >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>>> </pool>
>>>>> </config>
>>>>> On Sat, Jun 4,
>>>>> 2011 at 12:00
>>>>> PM, Ketan
>>>>> Maheshwari
>>>>> wrote:
>>>>> Jon,
>>>>> Thanks for
>>>>> trying out
>>>>> catsn on
>>>>> Beagle.
>>>>> I just
>>>>> tried it
>>>>> myself but
>>>>> could not
>>>>> reproduce
>>>>> the error
>>>>> you are
>>>>> getting.
>>>>> Have you
>>>>> made the
>>>>> changes
>>>>> that are
>>>>> mentioned
>>>>> in the README:
>>>>> Change
>>>>> workdir
>>>>> location
>>>>> in
>>>>> beagle-coaster.xml
>>>>> Change the
>>>>> project
>>>>> entry in
>>>>> the
>>>>> beagle-coaster.xml
>>>>> to your
>>>>> project name
>>>>> Ketan
>>>>> On Sat,
>>>>> Jun 4,
>>>>> 2011 at
>>>>> 11:50 AM,
>>>>> Jonathan S
>>>>> Monette
>>>>> wrote:
>>>>> Hello,
>>>>> I
>>>>> am
>>>>> trying
>>>>> to run
>>>>> the
>>>>> catsn
>>>>> test
>>>>> on
>>>>> beagle
>>>>> using
>>>>> the
>>>>> files
>>>>> in
>>>>> ~ketan/catsn.
>>>>> I
>>>>> have
>>>>> copied
>>>>> over
>>>>> this
>>>>> directory
>>>>> over
>>>>> to my
>>>>> home
>>>>> directory
>>>>> and I
>>>>> believe I
>>>>> set it
>>>>> up
>>>>> correctly.
>>>>> I did
>>>>> module
>>>>> load
>>>>> swift
>>>>> and
>>>>> the
>>>>> ran
>>>>> run.sh
>>>>> that
>>>>> was in
>>>>> this
>>>>> directory.
>>>>> I get
>>>>> this
>>>>> error.
>>>>> /soft/swift/0.92/bin/swift:
>>>>> eval:
>>>>> line
>>>>> 152:
>>>>> syntax
>>>>> error
>>>>> near
>>>>> unexpected
>>>>> token `('
>>>>> eval:
>>>>> line
>>>>> 152:
>>>>> `java
>>>>> -Xmx8192M
>>>>> -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>>>>> -DUID=1881
>>>>> -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>>> -Dswift.home=/soft/swift/0.92/bin/..
>>>>> -classpath
>>>>> /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>>> vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>>> e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>>> .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>>> /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>>> org.griphyn.vdl.karajan.Loader
>>>>> '-config'
>>>>> 'cf'
>>>>> '-tc.file'
>>>>> 'tc'
>>>>> '-sites.file'
>>>>> 'beagle-coaster.xml'
>>>>> 'catsn.swift'
>>>>> '-n=1''
>>>>> I
>>>>> there
>>>>> something
>>>>> else I
>>>>> need
>>>>> to
>>>>> load
>>>>> on
>>>>> beagle
>>>>> to
>>>>> make
>>>>> swift
>>>>> run
>>>>> accordingly?
>>>>> Any
>>>>> intelligent
>>>>> fool
>>>>> can
>>>>> make
>>>>> things
>>>>> bigger
>>>>> and
>>>>> more
>>>>> complex...
>>>>> It
>>>>> takes
>>>>> a
>>>>> touch
>>>>> of
>>>>> genius
>>>>> - and
>>>>> a lot
>>>>> of
>>>>> courage to
>>>>> move
>>>>> in the
>>>>> opposite
>>>>> direction.
>>>>> Albert
>>>>> Einstein
>>>>> Any
>>>>> intelligent
>>>>> fool can make
>>>>> things bigger
>>>>> and more
>>>>> complex... It
>>>>> takes a touch
>>>>> of genius -
>>>>> and a lot of
>>>>> courage to
>>>>> move in the
>>>>> opposite
>>>>> direction.
>>>>> - Albert Einstein
>>>> Any intelligent
>>>> fool can make
>>>> things bigger and
>>>> more complex... It
>>>> takes a touch of
>>>> genius - and a lot
>>>> of courage to move
>>>> in the opposite
>>>> direction.
>>>> - Albert Einstein
>>> Any intelligent fool can
>>> make things bigger and
>>> more complex... It takes
>>> a touch of genius - and
>>> a lot of courage to move
>>> in the opposite direction.
>>> - Albert Einstein
>>> make things bigger and more
>>> complex... It takes a touch
>>> of genius - and a lot of
>>> courage to move in the
>>> opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make
>>> complex... It takes a touch of
>>> genius - and a lot of courage to
>>> move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things
>>> bigger and more complex... It takes a
>>> touch of genius - and a lot of courage
>>> to move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things bigger and
>>> more complex... It takes a touch of genius - and
>>> a lot of courage to move in the opposite direction.
>>> - Albert Einstein
>>> Any intelligent fool can make things bigger and more
>>> complex... It takes a touch of genius - and a lot of
>>> - Albert Einstein
>> complex... It takes a touch of genius - and a lot of courage
>> - Albert Einstein
>> Any intelligent fool can make things bigger and more complex...
>> It takes a touch of genius - and a lot of courage to move in the
>> opposite direction.
>> - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110605/66e92ebd/attachment.html>
