[Swift-devel] Re: catsn on beagle
    Jonathan S Monette
    jonmon at utexas.edu
    Sun Jun  5 20:17:55 CDT 2011
So you are seeing the same problem?
On Sun, Jun 5, 2011 at 8:13 PM, ketan <ketancmaheshwari at gmail.com> wrote:
>  I do not know the reason why you are getting this. The PBS submit throws
> the following stderr:
> aprun: Apid 327667: Caught signal Terminated, sending to application
> Also on my another swift submission I am getting this as PBS submit stderr:
> [NID 00065] 2011-06-05 19:34:26 distributeControlMsg: Apid 327688 write
> failure to node 66, 10.128.0.67, port 607, Connection reset by peer
> I suspect the last maintenance/upgrade of Beagle might have caused this.
> Ketan
> On 6/5/11 1:35 PM, Jonathan S Monette wrote:
> I still have problems running this script.  I does not seem to ever
> execute.  I get this to stdout
>  Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
> locally)
>  RunID: 20110604-2338-5eik2hbb
> Progress:
> Progress:  Submitted:1
> Canceling job 173155.sdb
> Canceling job 173182.sdb
>  I had to C-c the run.  I would check qstat and it would say the job was
> executing in the development queue but it seems like it never ran.  Also it
> seems that the coasters job was cancelled twice during the Swift execution.
> On Sat, Jun 4, 2011 at 1:12 PM, Jonathan S Monette <jonmon at utexas.edu>wrote:
>> Ok.  Thanks.  and the (none) also appeared when I was on
>> login1.beagle.ci.uchicago.edu.  Thanks Ketan.
>>  On Sat, Jun 4, 2011 at 1:09 PM, ketan <ketancmaheshwari at gmail.com>wrote:
>>>  Yes, you should bring this to the attention of beagle sysadmins.
>>> On 6/4/11 1:01 PM, Jonathan S Monette wrote:
>>> Ok.  I have my job submitted and it is currently waiting in the queue.
>>>  besides manually resetting this variable everytime I am on beagle what else
>>> can be done?  Is this something that I should bring to the attention of the
>>> sys admins for beagle?
>>> On Sat, Jun 4, 2011 at 12:51 PM, Ketan Maheshwari <
>>>> Alright, so this is the issue. GLOBUS_HOSTNAME is picked up from
>>>> HOSTNAME and I do not know where does this none comes in your case.
>>>> In my case I get hostname: login2.beagle.ci.uchicago.edu
>>>> see if you can manually change this env variable and try to run again.
>>>> On Sat, Jun 4, 2011 at 12:49 PM, Jonathan S Monette <jonmon at utexas.edu>wrote:
>>>>> login2.beagle.ci.uchicago.edu.(none)
>>>>>  when you ran your test was in on login1 or login2?
>>>>> On Sat, Jun 4, 2011 at 12:47 PM, Ketan Maheshwari <
>>>>>> What does
>>>>>> echo $HOSTNAME give?
>>>>>> On Sat, Jun 4, 2011 at 12:44 PM, Jonathan S Monette <
>>>>>> jonmon at utexas.edu> wrote:
>>>>>>> I am not sure why that (none) appears.  Is this a variable that the
>>>>>>> system sets or do I need to set it?
>>>>>>> On Sat, Jun 4, 2011 at 12:39 PM, Ketan Maheshwari <
>>>>>>>> This suprises me because, I do not see that (none) in my
>>>>>>>> commandline.
>>>>>>>>  On Sat, Jun 4, 2011 at 12:38 PM, Jonathan S Monette <
>>>>>>>>> I added
>>>>>>>>> echo ${OPTIONS}
>>>>>>>>>     echo ${COG_OPTS}
>>>>>>>>>     echo ${LOCALCLASSPATH}
>>>>>>>>>     echo ${EXEC}
>>>>>>>>>     echo ${CMDLINE}
>>>>>>>>>  to the script.  It seems in the $OPTIONS variable this appears.
>>>>>>>>>  -Xmx8192M
>>>>>>>>> -Djava.endorsed.dirs=/home/jonmon/Library/Swift/swift-0.92/bin/../lib/endorsed
>>>>>>>>> -DUID=1881 -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>>>>>>>> -DCOG_INSTALL_PATH=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>>>>>>>> -Dswift.home=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>>>>>>>> -Djava.security.egd=file:///dev/urandom
>>>>>>>>>  There is the line
>>>>>>>>> DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)  I believe that is the
>>>>>>>>> parenthesis that is causing this to fail.  Now How do I fix it.
>>>>>>>>> On Sat, Jun 4, 2011 at 12:36 PM, Jonathan S Monette <
>>>>>>>>>> I may have found the error.  I download 0.92 binaries and changed
>>>>>>>>>> the swift command script.  I added
>>>>>>>>>> On Sat, Jun 4, 2011 at 12:26 PM, Jonathan S Monette <
>>>>>>>>>>> Same result. Same error
>>>>>>>>>>> On Sat, Jun 4, 2011 at 12:24 PM, ketan <
>>>>>>>>>>>>  can you try running the commandline by copying from run.sh and
>>>>>>>>>>>> pasting it at the prompt.
>>>>>>>>>>>> On 6/4/11 12:18 PM, Jonathan S Monette wrote:
>>>>>>>>>>>> I do have that project.  I did projects --avail and got back
>>>>>>>>>>>>  Project      PI                      Title
>>>>>>>>>>>> CI-CCR000013 Michael Wilde           The Swift Parallel
>>>>>>>>>>>> Scripting System
>>>>>>>>>>>>  Here is my run.sh file.  I execute with ./run.sh after I did
>>>>>>>>>>>> chmod +x run.sh
>>>>>>>>>>>>  #!/bin/bash
>>>>>>>>>>>> swift -config cf -tc.file tc -sites.file beagle-coaster.xml
>>>>>>>>>>>> catsn.swift -n=1
>>>>>>>>>>>>  I do have sh and cat in my path.  I can execute them.  Here is
>>>>>>>>>>>> what which sh and which cat produced.
>>>>>>>>>>>>  sh is /usr/bin/sh
>>>>>>>>>>>> cat is /bin/cat
>>>>>>>>>>>> On Sat, Jun 4, 2011 at 12:10 PM, ketan <
>>>>>>>>>>>>>  Can you try "projects --avail" command on beagle to see if you
>>>>>>>>>>>>> are member of a project.
>>>>>>>>>>>>> Else you will need to request membership. You can do this from
>>>>>>>>>>>>> this page:
>>>>>>>>>>>>> http://pads.ci.uchicago.edu/access/
>>>>>>>>>>>>> In any case, your error does not seem to be because of the
>>>>>>>>>>>>> above. Looks like '(' has sneaked in because of some unexpected typo in
>>>>>>>>>>>>> commandline .. can you doublecheck it.
>>>>>>>>>>>>> Also can you make sure that you have all the files: tc,
>>>>>>>>>>>>> beagle-coasters.xml cf in PATH, ie. are you able to access them w/o ./
>>>>>>>>>>>>> On 6/4/11 12:03 PM, Jonathan S Monette wrote:
>>>>>>>>>>>>>  I did change the work directory.  I however did not change
>>>>>>>>>>>>> the project name.  I do not know my project name so I kept the same project
>>>>>>>>>>>>> that was in there.  Here is my modified beagle-coasters.xml
>>>>>>>>>>>>>    <config>
>>>>>>>>>>>>>   <pool handle="pbs">
>>>>>>>>>>>>>     <execution provider="coaster" jobmanager="local:pbs"/>
>>>>>>>>>>>>>     <profile namespace="globus"
>>>>>>>>>>>>> key="project">CI-CCR000013</profile>
>>>>>>>>>>>>> key="ppn">24:cray:pack</profile>
>>>>>>>>>>>>> key="workersPerNode">24</profile>
>>>>>>>>>>>>>     <profile namespace="globus" key="maxTime">1000</profile>
>>>>>>>>>>>>>     <profile namespace="globus" key="slots">1</profile>
>>>>>>>>>>>>> key="nodeGranularity">1</profile>
>>>>>>>>>>>>>     <profile namespace="globus" key="maxNodes">1</profile>
>>>>>>>>>>>>>      <profile namespace="karajan"
>>>>>>>>>>>>> key="jobThrottle">.63</profile>
>>>>>>>>>>>>> key="initialScore">10000</profile>
>>>>>>>>>>>>>      <filesystem provider="local"/>
>>>>>>>>>>>>>     <workdirectory
>>>>>>>>>>>>> >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>>>>>>>>>>>   </pool>
>>>>>>>>>>>>> </config>
>>>>>>>>>>>>>   On Sat, Jun 4, 2011 at 12:00 PM, Ketan Maheshwari <
>>>>>>>>>>>>>>  Jon,
>>>>>>>>>>>>>> Thanks for trying out catsn on Beagle.
>>>>>>>>>>>>>> I just tried it myself but could not reproduce the error you
>>>>>>>>>>>>>> are getting. Have you made the changes that are mentioned in the README:
>>>>>>>>>>>>>> Change workdir location in beagle-coaster.xml
>>>>>>>>>>>>>> Change the project entry in the beagle-coaster.xml to your
>>>>>>>>>>>>>> project name
>>>>>>>>>>>>>> Ketan
>>>>>>>>>>>>>>  On Sat, Jun 4, 2011 at 11:50 AM, Jonathan S Monette <
>>>>>>>>>>>>>>>  Hello,
>>>>>>>>>>>>>>>    I am trying to run the catsn test on beagle using the
>>>>>>>>>>>>>>> files in ~ketan/catsn.  I have copied over this directory over to my home
>>>>>>>>>>>>>>> directory and I believe I set it up correctly.  I did module load swift and
>>>>>>>>>>>>>>> the ran run.sh that was in this directory.  I get this error.
>>>>>>>>>>>>>>>    /soft/swift/0.92/bin/swift: eval: line 152: syntax error
>>>>>>>>>>>>>>> near unexpected token `('
>>>>>>>>>>>>>>>  /soft/swift/0.92/bin/swift: eval: line 152: `java -Xmx8192M
>>>>>>>>>>>>>>> -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed -DUID=1881
>>>>>>>>>>>>>>> -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>>>>>>>>>>>>> -Dswift.home=/soft/swift/0.92/bin/.. -Djava.security.egd=
>>>>>>>>>>>>>>> file:///dev/urandom -classpath
>>>>>>>>>>>>>>> /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>>>>>>>>>>>>> vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>>>>>>>>>>>>> e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>>>>>>>>>>>>> .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>>>>>>>>>>>>> /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>>>>>>>>>>>>> org.griphyn.vdl.karajan.Loader '-config' 'cf' '-tc.file' 'tc' '-sites.file'
>>>>>>>>>>>>>>> 'beagle-coaster.xml' 'catsn.swift' '-n=1''
>>>>>>>>>>>>>>>  I there something else I need to load on beagle to make
>>>>>>>>>>>>>>> swift run accordingly?
>>>>>>>>>>>>>>> Any intelligent fool can make things bigger and more
>>>>>>>>>>>>>>> complex... It takes a touch of genius - and a lot of courage to move in the
>>>>>>>>>>>>>>> opposite direction.
>>>>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>>>> Any intelligent fool can make things bigger and more complex...
>>>>>>>>>>>>> It takes a touch of genius - and a lot of courage to move in the opposite
>>>>>>>>>>>>> direction.
>>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>>> direction.
>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>> direction.
>>>>>>>>>>> - Albert Einstein
>>>>>>>>>> Any intelligent fool can make things bigger and more complex... It
>>>>>>>>>> direction.
>>>>>>>>>> - Albert Einstein
>>>>>>>>> direction.
>>>>>>>>> - Albert Einstein
>>>>>>> direction.
>>>>>>> - Albert Einstein
>>>>> direction.
>>>>> - Albert Einstein
>>> Any intelligent fool can make things bigger and more complex... It takes
>>> a touch of genius - and a lot of courage to move in the opposite direction.
>>> - Albert Einstein
>> Any intelligent fool can make things bigger and more complex... It takes a
>> - Albert Einstein
> - Albert Einstein
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110605/452788fa/attachment.html>
