[Swift-devel] Re: catsn on beagle
    ketan
    ketancmaheshwari at gmail.com
    Sun Jun  5 20:13:44 CDT 2011
I do not know the reason why you are getting this. The PBS submit throws
the following stderr:
aprun: Apid 327667: Caught signal Terminated, sending to application
Also on my another swift submission I am getting this as PBS submit stderr:
[NID 00065] 2011-06-05 19:34:26 distributeControlMsg: Apid 327688 write
failure to node 66, 10.128.0.67, port 607, Connection reset by peer
I suspect the last maintenance/upgrade of Beagle might have caused this.
Ketan
On 6/5/11 1:35 PM, Jonathan S Monette wrote:
> I still have problems running this script.  I does not seem to ever
> execute.  I get this to stdout
> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
> locally)
> RunID: 20110604-2338-5eik2hbb
> Progress:
> Progress:  Submitted:1
> Canceling job 173155.sdb
> Canceling job 173182.sdb
> I had to C-c the run.  I would check qstat and it would say the job
> was executing in the development queue but it seems like it never ran.
>  Also it seems that the coasters job was cancelled twice during the
> Swift execution.
> On Sat, Jun 4, 2011 at 1:12 PM, Jonathan S Monette <jonmon at utexas.edu
> <mailto:jonmon at utexas.edu>> wrote:
>     Ok.  Thanks.  and the (none) also appeared when I was on
>     login1.beagle.ci.uchicago.edu
>     <http://login1.beagle.ci.uchicago.edu>.  Thanks Ketan.
>     On Sat, Jun 4, 2011 at 1:09 PM, ketan <ketancmaheshwari at gmail.com
>     <mailto:ketancmaheshwari at gmail.com>> wrote:
>         Yes, you should bring this to the attention of beagle sysadmins.
>         On 6/4/11 1:01 PM, Jonathan S Monette wrote:
>>         Ok.  I have my job submitted and it is currently waiting in
>>         the queue.  besides manually resetting this variable
>>         everytime I am on beagle what else can be done?  Is this
>>         something that I should bring to the attention of the sys
>>         admins for beagle?
>>         On Sat, Jun 4, 2011 at 12:51 PM, Ketan Maheshwari
>>             Alright, so this is the issue. GLOBUS_HOSTNAME is picked
>>             up from HOSTNAME and I do not know where does this none
>>             comes in your case.
>>             In my case I get hostname: login2.beagle.ci.uchicago.edu
>>             <http://login2.beagle.ci.uchicago.edu>
>>             see if you can manually change this env variable and try
>>             to run again.
>>             On Sat, Jun 4, 2011 at 12:49 PM, Jonathan S Monette
>>             <jonmon at utexas.edu <mailto:jonmon at utexas.edu>> wrote:
>>                 login2.beagle.ci.uchicago.edu.(none)
>>                 when you ran your test was in on login1 or login2?
>>                 On Sat, Jun 4, 2011 at 12:47 PM, Ketan Maheshwari
>>                     What does
>>                     echo $HOSTNAME give?
>>                     On Sat, Jun 4, 2011 at 12:44 PM, Jonathan S
>>                         I am not sure why that (none) appears.  Is
>>                         this a variable that the system sets or do I
>>                         need to set it?
>>                         On Sat, Jun 4, 2011 at 12:39 PM, Ketan
>>                         Maheshwari <ketancmaheshwari at gmail.com
>>                             This suprises me because, I do not see
>>                             that (none) in my commandline.
>>                             On Sat, Jun 4, 2011 at 12:38 PM, Jonathan
>>                                 I added
>>                                 echo ${OPTIONS}
>>                                     echo ${COG_OPTS}
>>                                     echo ${LOCALCLASSPATH}
>>                                     echo ${EXEC}
>>                                     echo ${CMDLINE}
>>                                 to the script.  It seems in the
>>                                 $OPTIONS variable this appears.
>>                                 -Xmx8192M
>>                                 -Djava.endorsed.dirs=/home/jonmon/Library/Swift/swift-0.92/bin/../lib/endorsed
>>                                 -DUID=1881
>>                                 -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>                                 -DCOG_INSTALL_PATH=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>                                 -Dswift.home=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>                                 -Djava.security.egd=file:///dev/urandom
>>                                 There is the line
>>                                  I believe that is the parenthesis
>>                                 that is causing this to fail.  Now
>>                                 How do I fix it.
>>                                 On Sat, Jun 4, 2011 at 12:36 PM,
>>                                     I may have found the error.  I
>>                                     download 0.92 binaries and
>>                                     changed the swift command script.
>>                                      I added
>>                                     On Sat, Jun 4, 2011 at 12:26 PM,
>>                                     Jonathan S Monette
>>                                         Same result. Same error
>>                                         On Sat, Jun 4, 2011 at 12:24
>>                                         PM, ketan
>>                                         wrote:
>>                                             can you try running the
>>                                             commandline by copying
>>                                             from run.sh and pasting
>>                                             it at the prompt.
>>                                             On 6/4/11 12:18 PM,
>>>                                             I do have that project.
>>>                                              I did projects --avail
>>>                                             and got back
>>>                                             Project      PI
>>>                                                          Title
>>>                                             CI-CCR000013 Michael
>>>                                             Wilde           The
>>>                                             Swift Parallel Scripting
>>>                                             System
>>>                                             Here is my run.sh file.
>>>                                              I execute with ./run.sh
>>>                                             after I did chmod +x run.sh
>>>                                             #!/bin/bash
>>>                                             swift -config cf
>>>                                             -tc.file tc -sites.file
>>>                                             beagle-coaster.xml
>>>                                             catsn.swift -n=1
>>>                                             I do have sh and cat in
>>>                                             my path.  I can execute
>>>                                             them.  Here is what
>>>                                             which sh and which cat
>>>                                             produced.
>>>                                             sh is /usr/bin/sh
>>>                                             cat is /bin/cat
>>>                                             12:10 PM, ketan
>>>                                             wrote:
>>>                                                 Can you try
>>>                                                 "projects --avail"
>>>                                                 command on beagle to
>>>                                                 see if you are
>>>                                                 member of a project.
>>>                                                 Else you will need
>>>                                                 to request
>>>                                                 membership. You can
>>>                                                 do this from this page:
>>>                                                 http://pads.ci.uchicago.edu/access/
>>>                                                 In any case, your
>>>                                                 error does not seem
>>>                                                 to be because of the
>>>                                                 above. Looks like
>>>                                                 '(' has sneaked in
>>>                                                 because of some
>>>                                                 unexpected typo in
>>>                                                 commandline .. can
>>>                                                 you doublecheck it.
>>>                                                 Also can you make
>>>                                                 sure that you have
>>>                                                 all the files: tc,
>>>                                                 beagle-coasters.xml
>>>                                                 cf in PATH, ie. are
>>>                                                 you able to access
>>>                                                 them w/o ./
>>>                                                 On 6/4/11 12:03 PM,
>>>                                                 Jonathan S Monette
>>>                                                 wrote:
>>>>                                                 I did change the
>>>>                                                 work directory.  I
>>>>                                                 however did not
>>>>                                                 change the project
>>>>                                                 name.  I do not
>>>>                                                 know my project
>>>>                                                 name so I kept the
>>>>                                                 same project that
>>>>                                                 was in there.  Here
>>>>                                                 is my modified
>>>>                                                 beagle-coasters.xml
>>>>                                                 <config>
>>>>                                                 <pool handle="pbs">
>>>>                                                 <execution
>>>>                                                 provider="coaster"
>>>>                                                 jobmanager="local:pbs"/>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="project">CI-CCR000013</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="ppn">24:cray:pack</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="workersPerNode">24</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="maxTime">1000</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="slots">1</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="nodeGranularity">1</profile>
>>>>                                                 <profile
>>>>                                                 namespace="globus"
>>>>                                                 key="maxNodes">1</profile>
>>>>                                                 <profile
>>>>                                                 namespace="karajan"
>>>>                                                 key="jobThrottle">.63</profile>
>>>>                                                 <profile
>>>>                                                 namespace="karajan"
>>>>                                                 key="initialScore">10000</profile>
>>>>                                                 <filesystem
>>>>                                                 provider="local"/>
>>>>                                                 <workdirectory
>>>>                                                 >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>>                                                 </pool>
>>>>                                                 </config>
>>>>                                                 On Sat, Jun 4, 2011
>>>>                                                 at 12:00 PM, Ketan
>>>>                                                 Maheshwari
>>>>                                                 wrote:
>>>>                                                     Jon,
>>>>                                                     Thanks for
>>>>                                                     trying out
>>>>                                                     catsn on Beagle.
>>>>                                                     I just tried it
>>>>                                                     myself but
>>>>                                                     could not
>>>>                                                     reproduce the
>>>>                                                     error you are
>>>>                                                     getting. Have
>>>>                                                     you made the
>>>>                                                     changes that
>>>>                                                     are mentioned
>>>>                                                     in the README:
>>>>                                                     Change workdir
>>>>                                                     location in
>>>>                                                     beagle-coaster.xml
>>>>                                                     Change the
>>>>                                                     project entry
>>>>                                                     in the
>>>>                                                     beagle-coaster.xml
>>>>                                                     to your project
>>>>                                                     name
>>>>                                                     Ketan
>>>>                                                     On Sat, Jun 4,
>>>>                                                     2011 at 11:50
>>>>                                                     AM, Jonathan S
>>>>                                                     Monette
>>>>                                                     wrote:
>>>>                                                         Hello,
>>>>                                                            I am
>>>>                                                         trying to
>>>>                                                         run the
>>>>                                                         catsn test
>>>>                                                         on beagle
>>>>                                                         using the
>>>>                                                         files in
>>>>                                                         ~ketan/catsn.
>>>>                                                          I have
>>>>                                                         copied over
>>>>                                                         this
>>>>                                                         directory
>>>>                                                         over to my
>>>>                                                         home
>>>>                                                         directory
>>>>                                                         and I
>>>>                                                         believe I
>>>>                                                         set it up
>>>>                                                         correctly.
>>>>                                                          I did
>>>>                                                         module load
>>>>                                                         swift and
>>>>                                                         the ran
>>>>                                                         run.sh that
>>>>                                                         was in this
>>>>                                                         directory.
>>>>                                                          I get this
>>>>                                                         error.
>>>>                                                         /soft/swift/0.92/bin/swift:
>>>>                                                         eval: line
>>>>                                                         152: syntax
>>>>                                                         error near
>>>>                                                         unexpected
>>>>                                                         token `('
>>>>                                                         eval: line
>>>>                                                         152: `java
>>>>                                                         -Xmx8192M
>>>>                                                         -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>>>>                                                         -DUID=1881
>>>>                                                         -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>>                                                         -Dswift.home=/soft/swift/0.92/bin/..
>>>>                                                         -classpath
>>>>                                                         /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>>                                                         vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>>                                                         e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>>                                                         .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>>                                                         /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>>                                                         org.griphyn.vdl.karajan.Loader
>>>>                                                         '-config'
>>>>                                                         'cf'
>>>>                                                         '-tc.file'
>>>>                                                         'tc'
>>>>                                                         '-sites.file'
>>>>                                                         'beagle-coaster.xml'
>>>>                                                         'catsn.swift'
>>>>                                                         '-n=1''
>>>>                                                         I there
>>>>                                                         something
>>>>                                                         else I need
>>>>                                                         to load on
>>>>                                                         beagle to
>>>>                                                         make swift
>>>>                                                         run
>>>>                                                         accordingly?
>>>>                                                         Any
>>>>                                                         intelligent
>>>>                                                         fool can
>>>>                                                         make things
>>>>                                                         bigger and
>>>>                                                         more
>>>>                                                         complex...
>>>>                                                         It takes a
>>>>                                                         touch of
>>>>                                                         genius -
>>>>                                                         and a lot
>>>>                                                         of courage
>>>>                                                         to move in
>>>>                                                         the
>>>>                                                         opposite
>>>>                                                         direction.
>>>>                                                         - Albert
>>>>                                                         Einstein
>>>>                                                 Any intelligent
>>>>                                                 fool can make
>>>>                                                 things bigger and
>>>>                                                 more complex... It
>>>>                                                 takes a touch of
>>>>                                                 genius - and a lot
>>>>                                                 of courage to move
>>>>                                                 in the opposite
>>>>                                                 direction.
>>>>                                                 - Albert Einstein
>>>                                             Any intelligent fool can
>>>                                             make things bigger and
>>>                                             more complex... It takes
>>>                                             a touch of genius - and
>>>                                             a lot of courage to move
>>>                                             in the opposite direction.
>>>                                             - Albert Einstein
>>                                         Any intelligent fool can make
>>                                         things bigger and more
>>                                         complex... It takes a touch
>>                                         of genius - and a lot of
>>                                         courage to move in the
>>                                         opposite direction.
>>                                         - Albert Einstein
>>                                     things bigger and more complex...
>>                                     It takes a touch of genius - and
>>                                     a lot of courage to move in the
>>                                     opposite direction.
>>                                     - Albert Einstein
>>                                 Any intelligent fool can make things
>>                                 bigger and more complex... It takes a
>>                                 touch of genius - and a lot of
>>                                 courage to move in the opposite
>>                                 direction.
>>                                 - Albert Einstein
>>                         Any intelligent fool can make things bigger
>>                         and more complex... It takes a touch of
>>                         genius - and a lot of courage to move in the
>>                         opposite direction.
>>                         - Albert Einstein
>>                 Any intelligent fool can make things bigger and more
>>                 complex... It takes a touch of genius - and a lot of
>>                 courage to move in the opposite direction.
>>                 - Albert Einstein
>>         complex... It takes a touch of genius - and a lot of courage
>>         - Albert Einstein
>     Any intelligent fool can make things bigger and more complex... It
>     takes a touch of genius - and a lot of courage to move in the
>     opposite direction.
>     - Albert Einstein
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110605/538d865e/attachment.html>
