[Swift-devel] Re: catsn on beagle
    Jonathan S Monette
    jonmon at utexas.edu
    Sat Jun  4 12:18:01 CDT 2011
I do have that project.  I did projects --avail and got back
Project      PI                      Title
CI-CCR000013 Michael Wilde           The Swift Parallel Scripting System
Here is my run.sh file.  I execute with ./run.sh after I did chmod +x run.sh
#!/bin/bash
swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=1
I do have sh and cat in my path.  I can execute them.  Here is what which sh
and which cat produced.
sh is /usr/bin/sh
cat is /bin/cat
On Sat, Jun 4, 2011 at 12:10 PM, ketan <ketancmaheshwari at gmail.com> wrote:
>  Can you try "projects --avail" command on beagle to see if you are member
> of a project.
> Else you will need to request membership. You can do this from this page:
> http://pads.ci.uchicago.edu/access/
> In any case, your error does not seem to be because of the above. Looks
> like '(' has sneaked in because of some unexpected typo in commandline ..
> can you doublecheck it.
> Also can you make sure that you have all the files: tc, beagle-coasters.xml
> cf in PATH, ie. are you able to access them w/o ./
> On 6/4/11 12:03 PM, Jonathan S Monette wrote:
> I did change the work directory.  I however did not change the project
> name.  I do not know my project name so I kept the same project that was in
> there.  Here is my modified beagle-coasters.xml
>  <config>
>   <pool handle="pbs">
>     <execution provider="coaster" jobmanager="local:pbs"/>
>     <profile namespace="globus" key="project">CI-CCR000013</profile>
>      <profile namespace="globus" key="ppn">24:cray:pack</profile>
>      <profile namespace="globus" key="workersPerNode">24</profile>
>     <profile namespace="globus" key="maxTime">1000</profile>
>     <profile namespace="globus" key="slots">1</profile>
>     <profile namespace="globus" key="nodeGranularity">1</profile>
>     <profile namespace="globus" key="maxNodes">1</profile>
>      <profile namespace="karajan" key="jobThrottle">.63</profile>
>     <profile namespace="karajan" key="initialScore">10000</profile>
>      <filesystem provider="local"/>
>     <workdirectory >/lustre/beagle/jonmon/Swift/work</workdirectory>
>   </pool>
> </config>
> On Sat, Jun 4, 2011 at 12:00 PM, Ketan Maheshwari <
>> Jon,
>> Thanks for trying out catsn on Beagle.
>> I just tried it myself but could not reproduce the error you are getting.
>> Have you made the changes that are mentioned in the README:
>> Change workdir location in beagle-coaster.xml
>> Change the project entry in the beagle-coaster.xml to your project name
>> Ketan
>> On Sat, Jun 4, 2011 at 11:50 AM, Jonathan S Monette <jonmon at utexas.edu>wrote:
>>> Hello,
>>>    I am trying to run the catsn test on beagle using the files in
>>> ~ketan/catsn.  I have copied over this directory over to my home directory
>>> and I believe I set it up correctly.  I did module load swift and the ran
>>> run.sh that was in this directory.  I get this error.
>>>  /soft/swift/0.92/bin/swift: eval: line 152: syntax error near
>>> unexpected token `('
>>> /soft/swift/0.92/bin/swift: eval: line 152: `java -Xmx8192M
>>> -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed -DUID=1881
>>> -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>> -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>> -Dswift.home=/soft/swift/0.92/bin/.. -Djava.security.egd=
>>> file:///dev/urandom -classpath
>>> /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>> vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>> e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>> .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>> /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>> org.griphyn.vdl.karajan.Loader '-config' 'cf' '-tc.file' 'tc' '-sites.file'
>>> 'beagle-coaster.xml' 'catsn.swift' '-n=1''
>>>  I there something else I need to load on beagle to make swift run
>>> accordingly?
>>> Any intelligent fool can make things bigger and more complex... It takes
>>> a touch of genius - and a lot of courage to move in the opposite direction.
>>> - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It takes a
> - Albert Einstein
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110604/14195d27/attachment.html>
