[Swift-devel] OSG hang
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul 14 13:25:46 CDT 2011
On Thu, 2011-07-14 at 13:22 -0500, Michael Wilde wrote:
> Try this:
> export GLOBUS_HOSTNAME=externalIPAddr # set it to the 50.x.y.z addr
> export GLOBUS_TCP_PORT_RANGE=50000,51000
> export GLOBUS_TCP_SOURCE_RANGE=50000,51000
> Then test both globus-url-copy and globusrun from swift/bin (you will
> need simple RSL for globusrun)
> Then test Swift manually from the VM
> Then test with a Karajan script
> Then test the Swift script
> Use a single sleep job, eg sleep 1234, so you can spot it running on
> the head node.
> Mihael, can you help walk Jon through the above steps or suggest
> another approach?
I will. The steps you mention are what I would try.
