[Swift-devel] OSG hang
Michael Wilde wilde at mcs.anl.gov
Thu Jul 14 13:22:56 CDT 2011
Try this:
export GLOBUS_HOSTNAME=externalIPAddr # set it to the 50.x.y.z addr
export GLOBUS_TCP_PORT_RANGE=50000,51000
export GLOBUS_TCP_SOURCE_RANGE=50000,51000
Then test both globus-url-copy and globusrun from swift/bin (you will need simple RSL for globusrun)
Then test Swift manually from the VM
Then test with a Karajan script
Then test the Swift script
Use a single sleep job, eg sleep 1234, so you can spot it running on the head node.
Mihael, can you help walk Jon through the above steps or suggest another approach?
Mike
----- Original Message -----
Hello,
I am trying to submit jobs from an Amazon VM to an OSG site. I have tried Engage VO sites with a proxy created by both grid-proxy-init and voms-proxy-init. When running swift it says it submitted the job but it looks like nothing is executing. This happens when using fork, condor, and pbs. I can successfully execute the script from communicado to OSG using fork with barely any wait time.
The files are located in ~jonmon/OSG.0000 on the ci machines.
I have filed a bug in bugzilla.
Bug 471 - OSG hangs from VM
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110714/32db5369/attachment.html>
