[Swift-devel] OSG hang
    Jonathan Monette
    jonmon at utexas.edu
    Thu Jul 14 13:28:30 CDT 2011
What is the distinction between testing swift manually from the VM and then test the Swift script?
On Jul 14, 2011, at 1:25 PM, Mihael Hategan wrote:
> On Thu, 2011-07-14 at 13:22 -0500, Michael Wilde wrote:
>> Try this:
>> export GLOBUS_HOSTNAME=externalIPAddr # set it to the 50.x.y.z addr
>> export GLOBUS_TCP_PORT_RANGE=50000,51000
>> export GLOBUS_TCP_SOURCE_RANGE=50000,51000
>> Then test both globus-url-copy and globusrun from swift/bin (you will
>> need simple RSL for globusrun)
>> Then test Swift manually from the VM
>> Then test with a Karajan script
>> Then test the Swift script
>> Use a single sleep job, eg sleep 1234, so you can spot it running on
>> the head node.
>> Mihael, can you help walk Jon through the above steps or suggest
>> another approach?
> I will. The steps you mention are what I would try.
