[Swift-devel] Swift compile issues on IBI cluster
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Tue Jan 25 16:58:45 CST 2011
I don't know if it pays to worry about it then
- Tim
On Mon, Jan 24, 2011 at 12:07 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
> Then my theory is wrong.
> I can't do much without being able to reproduce this. So there are two
> choices: get access to the IBI cluster or let it go.
> Mihael
> On Mon, 2011-01-24 at 08:37 -0600, Tim Armstrong wrote:
> > It doesn't appear that changing the version of xerces helps.  I'm not
> > that familiar with the java.endorsed.dirs mechanism, but I believe I'm
> > using it correctly: adding the xerces jars to the class path and then
> > adding the containing directory as an endorsed dir.
> > I still get exactly the same failure.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110125/12aa41ca/attachment.html>
