[Swift-devel] Swift compile issues on IBI cluster
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jan 24 12:07:45 CST 2011
Then my theory is wrong.
I can't do much without being able to reproduce this. So there are two
choices: get access to the IBI cluster or let it go.
Mihael
On Mon, 2011-01-24 at 08:37 -0600, Tim Armstrong wrote:
> It doesn't appear that changing the version of xerces helps.  I'm not
> that familiar with the java.endorsed.dirs mechanism, but I believe I'm
> using it correctly: adding the xerces jars to the class path and then
> adding the containing directory as an endorsed dir.
> I still get exactly the same failure.
