[Swift-devel] No provider specified error
Jonathan Monette jon.monette at gmail.com
Sun Jan 23 22:18:23 CST 2011
Mihael,
    I just updated to cog-r3043 and swift-r4031.  I now get this swift
error:
Execution failed:
     No 'proxy' provider or alias found. Available providers: [cobalt,
gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor, http,
coaster-persistent, pbs, ftp, gsiftp-old, local, sge]. Aliases: gt4 <->
gt4.0.2, gt4.0.1, gt3.9.5, gt4.0.0; condor <-> condorlocal; cobalt <->
cobaltlocal; gsiftp <-> gridftp; pbs <-> pbslocal; gsiftp-old <->
gridftp-old; local <-> file;
Upon inspecting the log file I got found this Java error:
2011-01-23 18:31:27,221-0600 INFO  AbstractionProperties No properties
for provider proxy. Using empty properties
2011-01-23 18:31:27,227-0600 INFO  vdl:execute END_FAILURE thread=0-3
tr=mImgtbl
2011-01-23 18:31:27,234-0600 DEBUG VDL2ExecutionContext sys:throw @
execute-default.k, line: 45: Exception in mImgtbl:
Arguments: [proj_dir, images.tbl]
Host: localhost
Directory: rectified-20110123-1707-ptqrq9j5/jobs/3/mImgtbl-3krv2x4kTODO:
outs
Host: localhost
outs
Caused by: No 'proxy' provider or alias found. Available providers:
[cobalt, gsiftp, coaster, webdav, dcache, ssh, gt4, gt2, condor, http,
Caused by:
org.globus.cog.abstraction.impl.common.task.InvalidProviderException: No
'proxy' provider or alias found. Available providers: [cobalt, gsiftp,
     at
org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
     at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:27)
     at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:32)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:340)
     at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:173)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:181)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:309)
     at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
     at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:50)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:26)
     at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:238)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:289)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:402)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:343)
     at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:230)
     at
     at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:44)
     at
edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
     at
edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
     at
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
     at
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
     at java.lang.Thread.run(Thread.java:662)
Caused by:
     at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
     at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:153)
     at
org.globus.cog.karajan.workflow.nodes.grid.GridExec.taskFailed(GridExec.java:373)
     at
org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.statusChanged(AbstractGridNode.java:276)
     at org.griphyn.vdl.karajan.lib.Execute.statusChanged(Execute.java:127)
     at
org.globus.cog.karajan.scheduler.AbstractScheduler.fireJobStatusChangeEvent(AbstractScheduler.java:168)
     at
org.globus.cog.karajan.scheduler.LateBindingScheduler.statusChanged(LateBindingScheduler.java:675)
     at
org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler.statusChanged(WeightedHostScoreScheduler.java:422)
     at
org.griphyn.vdl.karajan.VDSAdaptiveScheduler.statusChanged(VDSAdaptiveScheduler.java:410)
     at
org.globus.cog.abstraction.impl.common.task.TaskImpl.notifyListeners(TaskImpl.java:240)
     at
org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:228)
     at
org.globus.cog.abstraction.impl.common.AbstractDelegatedTaskHandler.failTask(AbstractDelegatedTaskHandler.java:54)
     at
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:220)
     at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
     at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
     at java.util.concurrent.FutureTask.run(FutureTask.java:138)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
     ... 1 more
Caused by:
     at
org.globus.cog.abstraction.impl.common.AbstractionProperties.getProperties(AbstractionProperties.java:138)
     at
org.globus.cog.abstraction.impl.common.AbstractionFactory.newObject(AbstractionFactory.java:136)
     at
org.globus.cog.abstraction.impl.common.AbstractionFactory.newFileResource(AbstractionFactory.java:112)
     at
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.copy(JobSubmissionTaskHandler.java:293)
     at
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stage(JobSubmissionTaskHandler.java:272)
     at
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.stageIn(JobSubmissionTaskHandler.java:283)
     at
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.run(JobSubmissionTaskHandler.java:159)
     ... 6 more
2011-01-23 18:31:27,274-0600 INFO  ExecutionContext Detailed exception:
Host: localhost
outs
Caused by:
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
Caused by:
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     at
     ... 1 more
Caused by:
     at
     at
     at
     at
     at
     at
     at
     ... 6 more
I am running on PADS and here is my sites.xml file:
<config>
<pool handle="localhost">
<execution provider="local" />
<filesystem provider="local" />
<profile key="jobThrottle" namespace="karajan">.05</profile>
<profile key="SWIFT_GEN_SCRIPTS" namespace="env">1</profile>
<workdirectory>/gpfs/pads/swift/jonmon/Swift/work/localhost</workdirectory>
</pool>
<pool handle="pads">
<execution jobmanager="local:pbs" provider="coaster" />
<profile key="maxtime" namespace="globus">3600</profile>
<profile key="internalhostname" namespace="globus">192.5.86.6</profile>
<profile key="workersPerNode" namespace="globus">1</profile>
<profile key="slots" namespace="globus">40</profile>
<profile key="nodeGranularity" namespace="globus">1</profile>
<profile key="maxNodes" namespace="globus">1</profile>
<profile key="queue" namespace="globus">fast</profile>
<profile key="jobThrottle" namespace="karajan">1</profile>
<profile key="initialScore" namespace="karajan">10000</profile>
<workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
</pool>
</config>
Has anyone else seen this error or Mihael have you witnessed this?
