[Swift-devel] Re: provider staging stage-in rate on localhost and PADS
Michael Wilde wilde at mcs.anl.gov
Wed Jan 19 10:12:28 CST 2011
Continuing to work on resolving this problem.
I think the next step is to methodically test provider staginug moving from the single-node test to multi-node local (pads) and then to multi-node wan tests.
Now that the native coaster job rate to a single one-core worker is better understood (and seems to be 4-5 jobs per second) we can now devise tests with a better understanding of more factors involved.
I tried a local test on pads login(at a fairly quiet time, unloaded) as follows:
- local coasters service (in Swift jvm)
- app is "mv" (to avoid extra data movement)
- same input data file is used (so its likely in kernel block cache)
- unique output file is used
- swift and cwd is on /scratch local disk
- file is 3MB (to be closer to Allan's 2.3 MB)
- mv app stages file to worker and back (no app reads or writes)
- workers per node = 8 (on an 8 core host)
- throttle of 200 jobs (2.0)
- 100 jobs per swift script invocation
I get just over 5 apps/sec or 30MB/sec with this setup.
Allan, I'd like to suggest you take it from here, but lets talk as soon as possible this morning to make a plan.
One approach that may be fruitful is to re-design a remote test that is closer to what a real scec workload would be (basically your prior tests with some adjustment to the concurrency: more workers per site, and more overall files going in parallel.
Then, every time we have a new insight or code change, re-test the larger-scale WAN test in parallel with continuing down the micro-test methods.  That way, as soon as we hit a breakthrough that reaches your requires WAN data transfer rate, you can restart the full scec workflow, while we continue to analyze swift behavior issues with the simpler micro benchmarks.
Mike
----- Original Message -----
> Ok, so I committed a fix to make the worker send files a bit faster
> and
> adjusted the buffer sizes a bit. There is a trade-off between per
> worker
> performance and number of workers, so this should probably be a
> setting
> of some sort (since when there are many workers, the client bandwidth
> becomes the bottleneck).
> With a plain cat, 4 workers, 1 job/w, and 32M files I get this:
> [IN]: Total transferred: 7.99 GB, current rate: 23.6 MB/s, average
> rate:
> 16.47 MB/s
> [MEM] Heap total: 155.31 MMB, Heap used: 104.2 MMB
> [OUT] Total transferred: 8 GB, current rate: 0 B/s, average rate:
> 16.49
> MB/s
> Final status: time:498988 Finished successfully:256
> Time: 500.653, rate: 0 j/s
> So the system probably sees 96 MB/s combined reads and writes. I'd be
> curious how this looks without caching, but during the run the
> computer
> became laggy, so it's saturating something in the OS and/or hardware.
> I'll test on a cluster next.
> On Sun, 2011-01-16 at 18:02 -0800, Mihael Hategan wrote:
> > On Sun, 2011-01-16 at 19:38 -0600, Allan Espinosa wrote:
> > > So for the measurement interface, are you measuring the total data
> > > received as
> > > the data arrives or when the received file is completely written
> > > to the job
> > > directory.
> > The average is all the bytes that go from client to all the workers
> > over
> > the entire time spent to run the jobs.
> > > I was measuring from the logs from JOB_START to JOB_END. I assumed
> > > the actualy
> > > job execution to be 0. The 7MB/s probably corresponds to Mihael's
> > > stage out
> > > results. the cat jobs dump to stdout (redirected to a file in the
> > > swift
> > > wrapper) probably shows the same behavior as the stageout.
> > I'm becoming less surprised about 7MB/s in the local case. You have
> > to
> > multiply that by 6 to get the real disk I/O bandwidth:
> > 1. client reads from disk
> > 2. worker writes to disk
> > 3. cat reads from disk
> > 4. cat writes to disk
> > 5. worker reads from disk
> > 6. client writes to disk
> > If it all happens on a single disk, then it adds up to about 42
> > MB/s,
> > which is a reasonable fraction of what a normal disk can do. It
> > would be
> > useful to do a dd from /dev/zero to see what the actual disk
> > performance
> > is.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
