[Swift-devel] Problem with 0.92 sending jobs to OSG via Condor-G
Michael Wilde
wilde at mcs.anl.gov
Wed Jan 12 23:35:32 CST 2011
Im trying my first tests of 0.92 on engage-submit, sending 100 trivial cat jobs to 10 OSG sites.
My jobs seem to be all dying with the error "Found illegal unescaped double-quote" (see below).
Has anyone successfully run a Condor-G job on OSG with 0.92?
I'll dig deeper and try the same test with the older version of trunk that Marc has been using here with better success. Will also try a single job run and capture a simpler log and the condor-g submit file.
Allan, have you tried 0.92 against COndor-G? If not, could you?
Sarah, we should add some Condor-G-to-GT2 testing to 0.92 validation I think.
- Mike
Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot submit job: Could not submit job (condor_submit reported an exit code of 1). Submitting job(s)
Found illegal unescaped double-quote: "" -e /bin/cat -out outdir/f.0065.out -err stderr.txt -i -d outdir -if data.txt -of outdir/f.0065.out -k "" -cdmfile "" -status file -a data.txtThe full arguments you specified were: /osg/data/engage/tmp/osg.hpc.ufl.edu/catsn-20110113-0025-vv4p4up3/shared/_swiftwrap cat-ajxnee4k -jobdir a -scratch "" -e /bin/cat -out outdir/f.0065.out -err stderr.txt -i -d outdir -if data.txt -of outdir/f.0065.out -k "" -cdmfile "" -status file -a data.txt
Script is:
e$ cat catsn.swift
type file;
app (file o) cat (file i)
cat @i stdout=@o;
file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
foreach j in [1:@toint(@arg("n","1"))] {
file data<"data.txt">;
out[j] = cat(data);
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
