[Swift-devel] Errors compiling 0.92 with Java 1.5
Mihael Hategan hategan at mcs.anl.gov
Wed Jan 12 20:33:09 CST 2011
On Wed, 2011-01-12 at 20:24 -0600, Michael Wilde wrote:
> Thanks, David.
> Heres a process question for the group:
> - should we fix this in 0.92?
Yes.
>   - by saying 1.6 or above is required (with a poiter to the patch for 1.5 users?)
>   - by applying the patch to 0.92?
I vote for the latter.
> - if so, how should we mark 0.92 showstoppers in bugzilla?
Yes.
> - lets agree on a test-fix-test-release approach for sealing and releasing 0.92
> Ie, identify the showstoppers, fix 'em, test, add showstoppers only as necessary, and repeat till no more showstoppers.
> - Mike
> > Yep, it's #239. I saw it first on sisboombah.
> > https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=239
> > On Wed, Jan 12, 2011 at 8:58 PM, David Kelly <dk0966 at cs.ship.edu>
> > wrote:
> > > I ran into a similar issue. Here is the patch I wrote for it (there
> > > should also be a bug report)
> > > On Wed, Jan 12, 2011 at 8:53 PM, Michael Wilde <wilde at mcs.anl.gov>
> > > wrote:
> > >> I get the errors below when I build 0.92 with this Java and ant on
> > >> RENCI engage-submit:
> > >> e$ which java
> > >> /opt/osg/1.0.0/jdk1.5/bin/java
> > >> e$ java -version
> > >> java version "1.5.0_14"
> > >> Java(TM) 2 Runtime Environment, Standard Edition (build
> > >> 1.5.0_14-b03)
> > >> Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_14-b03, mixed mode)
> > >> e$ which javac
> > >> /opt/osg/1.0.0/jdk1.5/bin/javac
> > >> e$ ant -version
> > >> Apache Ant version 1.6.5 compiled on June 2 2005
> > >> e$
> > >> The same svn rev seems to uild clean with 1.6 on PADS.
> > >> I dont think this necessarily needs to be fixed; but at least
> > >> documented if we no longer work with 1.5. (I recall we said we wont
> > >> support 1.4 -- or was that 1.5?)
> > >> - Mike
> > >> Errors:
> > >> compile:
> > >>     [echo] [util]: COMPILE
> > >>    [mkdir] Created dir:
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/build
> > >>    [javac] Compiling 53 source files to
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:71:
> > >>    method does not override a method from its superclass
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:105:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:144:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:227:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:232:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:237:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:242:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:247:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:252:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac]
> > >>    /home/wilde/swift/src/0.92/cog/modules/util/src/org/globus/cog/util/CopyOnWriteArrayList.java:257:
> > >>    [javac] @Override
> > >>    [javac] ^
> > >>    [javac] Note: Some input files use or override a deprecated API.
> > >>    [javac] Note: Recompile with -Xlint:deprecation for details.
> > >>    [javac] Note: Some input files use unchecked or unsafe
> > >>    operations.
> > >>    [javac] Note: Recompile with -Xlint:unchecked for details.
> > >>    [javac] 10 errors
> > >> BUILD FAILED
> > >> /home/wilde/swift/src/0.92/cog/modules/swift/build.xml:73: The
> > >> following error occurred while executing this line:
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:444: The following error
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:79: The following error
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:52: The following error
> > >> /home/wilde/swift/src/0.92/cog/modules/swift/dependencies.xml:4:
> > >> The following error occurred while executing this line:
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:163: The following error
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:168: The following error
> > >> /home/wilde/swift/src/0.92/cog/modules/karajan/build.xml:59: The
> > >> /home/wilde/swift/src/0.92/cog/modules/karajan/dependencies.xml:4:
> > >> /home/wilde/swift/src/0.92/cog/modules/abstraction/build.xml:58:
> > >> /home/wilde/swift/src/0.92/cog/modules/abstraction/dependencies.xml:4:
> > >> /home/wilde/swift/src/0.92/cog/modules/abstraction-common/build.xml:63:
> > >> /home/wilde/swift/src/0.92/cog/modules/abstraction-common/dependencies.xml:7:
> > >> /home/wilde/swift/src/0.92/cog/modules/util/build.xml:59: The
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:465: The following error
> > >> /home/wilde/swift/src/0.92/cog/mbuild.xml:228: Compile failed; see
> > >> the compiler error output for details.
> > >> Total time: 20 seconds
> > >> e$ which java
> > >> e$ java -version
> > >> 1.5.0_14-b03)
> > >> e$ cd
> > >> e$ ls
> > >> bin ftdock glenslogs.tar.gz osgcat.sh osgfact out.ps out.qstat
> > >> swift t1.stderr t1.sub t2.sub
> > >> buildnrun.sh glasslogs.tgz mygroup osgcat.sh~ out out.ps2 pfgroup
> > >> t1.log t1.stdout t1.sub~
> > >> e$ which javac
> > >> e$ ant -version
> > >> e$
> > >> Michael Wilde
> > >> Computation Institute, University of Chicago
> > >> Mathematics and Computer Science Division
> > >> Argonne National Laboratory
> > >> _______________________________________________
> > >> Swift-devel mailing list
> > >> Swift-devel at ci.uchicago.edu
> > >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
