[Swift-devel] Problem with 0.92 sending jobs to OSG via Condor-G
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jan 12 23:43:14 CST 2011
An initial test with an older trunk (~mid-december, swift-r3703 cog-r2925 cog modified locally) seems to work fine with the same tc, sites, and properties file.
I need to check what local mods I had applied, but I think its more likely that some Condor submit file quoting fix fell off in 0.92 integration.
So Marc, sorry - this release is not usable for you yet.
- Mike
----- Original Message -----
> Im trying my first tests of 0.92 on engage-submit, sending 100 trivial
> cat jobs to 10 OSG sites.
> My jobs seem to be all dying with the error "Found illegal unescaped
> double-quote" (see below).
> Has anyone successfully run a Condor-G job on OSG with 0.92?
> I'll dig deeper and try the same test with the older version of trunk
> that Marc has been using here with better success. Will also try a
> single job run and capture a simpler log and the condor-g submit file.
> Allan, have you tried 0.92 against COndor-G? If not, could you?
> Sarah, we should add some Condor-G-to-GT2 testing to 0.92 validation I
> think.
> - Mike
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job: Could not submit job (condor_submit reported an
> exit code of 1). Submitting job(s)
> Found illegal unescaped double-quote: "" -e /bin/cat -out
> outdir/f.0065.out -err stderr.txt -i -d outdir -if data.txt -of
> outdir/f.0065.out -k "" -cdmfile "" -status file -a data.txtThe full
> arguments you specified were:
> /osg/data/engage/tmp/osg.hpc.ufl.edu/catsn-20110113-0025-vv4p4up3/shared/_swiftwrap
> cat-ajxnee4k -jobdir a -scratch "" -e /bin/cat -out outdir/f.0065.out
> -err stderr.txt -i -d outdir -if data.txt -of outdir/f.0065.out -k ""
> Script is:
> e$ cat catsn.swift
> type file;
> app (file o) cat (file i)
> cat @i stdout=@o;
> file out[]<simple_mapper; location="outdir",
> prefix="f.",suffix=".out">;
> foreach j in [1:@toint(@arg("n","1"))] {
> file data<"data.txt">;
> out[j] = cat(data);
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
