[Swift-devel] Swift jobs failing
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 20:17:15 CDT 2011
Authentication failed [Caused by: Defective credential detected [Caused
by: CRL for CA "C=US,O=National Center for Supercomputing
Applications,OU=Certificate Authorities,CN=MyProxy" has expired.]]
Sorry, but things cannot work properly if certificates are messed up.
Please complain to support at ci.
In the mean time I committed a patch to print better error messages in
such cases (i.e. the above message). So please test that.
On Thu, 2011-08-25 at 18:13 -0500, Jonathan Monette wrote:
> www.ci.uchicago.edu/~jonmon/logs/coasters.log.tar.gz
> On Aug 25, 2011, at 6:03 PM, Mihael Hategan wrote:
> > On Thu, 2011-08-25 at 17:51 -0500, Jonathan Monette wrote:
> >> my bad….try www.ci.uchicago.edu/~jonmon/logs/coasters.log
> > Could you gzip that?
> >> On Aug 25, 2011, at 5:41 PM, Mihael Hategan wrote:
> >>> mike at blabla:~/tmp$ wget
> >>> http://www.ci.uchicago.edu/~jonmon/log/coaster.log
> >>> --2011-08-25 15:40:31--
> >>> Resolving www.ci.uchicago.edu... 192.5.86.67
> >>> Connecting to www.ci.uchicago.edu|192.5.86.67|:80... connected.
> >>> HTTP request sent, awaiting response... 404 Not Found
> >>> 2011-08-25 15:40:32 ERROR 404: Not Found.
> >>> On Thu, 2011-08-25 at 16:43 -0500, Jonathan Monette wrote:
> >>>> Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
> >>>> On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
> >>>>> Can you post the coaster log on the remote machine?
> >>>>> On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
> >>>>>> Ok.  I will check my configuration.  I don't see very helpful messages
> >>>>>> in the log file but I will give a closer look.  More information to
> >>>>>> follow.
> >>>>>> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> >>>>>>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
> >>>>>>> do not see such messages.
> >>>>>>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
> >>>>>>> <jonmon at mcs.anl.gov> wrote:
> >>>>>>>      This also seems to be happening in trunk.  Is anyone seeing
> >>>>>>>      this issue with there code?
> >>>>>>>      On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> >>>>>>>> I started a run of my SwiftMontage work and all the jobs
> >>>>>>>      keep failing.  No progress is being made and the swift
> >>>>>>>      stdout will have the line "failed but can retry: 'some
> >>>>>>>      number'".  The log is located at
> >>>>>>>      www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
> >>>>>>>> _______________________________________________
> >>>>>>>> Swift-devel mailing list
> >>>>>>>> Swift-devel at ci.uchicago.edu
> >>>>>>>      https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >>>>>>> Ketan
