[Swift-devel] Swift jobs failing
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 21:28:35 CDT 2011
Never mind.  I found a similar error.
[Caused by: Defective credential detected [Caused by: CRL for CA "DC=org,DC=DOEGrids,OU=Certificate Authorities,CN=DOEGrids CA 1" has expired.]]
I will email support at ci and let them know of the situation and if they can up the frequency they update the CAs.
On Aug 25, 2011, at 8:17 PM, Mihael Hategan wrote:
> Authentication failed [Caused by: Defective credential detected [Caused
> by: CRL for CA "C=US,O=National Center for Supercomputing
> Applications,OU=Certificate Authorities,CN=MyProxy" has expired.]]
> Sorry, but things cannot work properly if certificates are messed up.
> Please complain to support at ci.
> In the mean time I committed a patch to print better error messages in
> such cases (i.e. the above message). So please test that.
> On Thu, 2011-08-25 at 18:13 -0500, Jonathan Monette wrote:
>> www.ci.uchicago.edu/~jonmon/logs/coasters.log.tar.gz
>> On Aug 25, 2011, at 6:03 PM, Mihael Hategan wrote:
>>> On Thu, 2011-08-25 at 17:51 -0500, Jonathan Monette wrote:
>>>> my bad….try www.ci.uchicago.edu/~jonmon/logs/coasters.log
>>> Could you gzip that?
>>>> On Aug 25, 2011, at 5:41 PM, Mihael Hategan wrote:
>>>>> mike at blabla:~/tmp$ wget
>>>>> http://www.ci.uchicago.edu/~jonmon/log/coaster.log
>>>>> --2011-08-25 15:40:31--
>>>>> Resolving www.ci.uchicago.edu... 192.5.86.67
>>>>> Connecting to www.ci.uchicago.edu|192.5.86.67|:80... connected.
>>>>> HTTP request sent, awaiting response... 404 Not Found
>>>>> 2011-08-25 15:40:32 ERROR 404: Not Found.
>>>>> On Thu, 2011-08-25 at 16:43 -0500, Jonathan Monette wrote:
>>>>>> Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
>>>>>> On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
>>>>>>> Can you post the coaster log on the remote machine?
>>>>>>> On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
>>>>>>>> Ok.  I will check my configuration.  I don't see very helpful messages
>>>>>>>> in the log file but I will give a closer look.  More information to
>>>>>>>> follow.
>>>>>>>> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
>>>>>>>>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
>>>>>>>>> do not see such messages.
>>>>>>>>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
>>>>>>>>> <jonmon at mcs.anl.gov> wrote:
>>>>>>>>>     This also seems to be happening in trunk.  Is anyone seeing
>>>>>>>>>     this issue with there code?
>>>>>>>>>     On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
>>>>>>>>>> I started a run of my SwiftMontage work and all the jobs
>>>>>>>>>     keep failing.  No progress is being made and the swift
>>>>>>>>>     stdout will have the line "failed but can retry: 'some
>>>>>>>>>     number'".  The log is located at
>>>>>>>>>     www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>>>>>>> Ketan
