[Swift-devel] Swift jobs failing
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 18:13:12 CDT 2011
www.ci.uchicago.edu/~jonmon/logs/coasters.log.tar.gz
On Aug 25, 2011, at 6:03 PM, Mihael Hategan wrote:
> On Thu, 2011-08-25 at 17:51 -0500, Jonathan Monette wrote:
>> my bad….try www.ci.uchicago.edu/~jonmon/logs/coasters.log
> Could you gzip that?
>> On Aug 25, 2011, at 5:41 PM, Mihael Hategan wrote:
>>> mike at blabla:~/tmp$ wget
>>> http://www.ci.uchicago.edu/~jonmon/log/coaster.log
>>> --2011-08-25 15:40:31--
>>> Resolving www.ci.uchicago.edu... 192.5.86.67
>>> Connecting to www.ci.uchicago.edu|192.5.86.67|:80... connected.
>>> HTTP request sent, awaiting response... 404 Not Found
>>> 2011-08-25 15:40:32 ERROR 404: Not Found.
>>> On Thu, 2011-08-25 at 16:43 -0500, Jonathan Monette wrote:
>>>> Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
>>>> On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
>>>>> Can you post the coaster log on the remote machine?
>>>>> On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
>>>>>> Ok.  I will check my configuration.  I don't see very helpful messages
>>>>>> in the log file but I will give a closer look.  More information to
>>>>>> follow.
>>>>>> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
>>>>>>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
>>>>>>> do not see such messages.
>>>>>>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
>>>>>>> <jonmon at mcs.anl.gov> wrote:
>>>>>>>      This also seems to be happening in trunk.  Is anyone seeing
>>>>>>>      this issue with there code?
>>>>>>>      On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
>>>>>>>> I started a run of my SwiftMontage work and all the jobs
>>>>>>>      keep failing.  No progress is being made and the swift
>>>>>>>      stdout will have the line "failed but can retry: 'some
>>>>>>>      number'".  The log is located at
>>>>>>>      www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
>>>>>>>> _______________________________________________
>>>>>>>> Swift-devel mailing list
>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>      https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>>>>> Ketan
