[Swift-devel] Swift jobs failing
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 18:03:59 CDT 2011
On Thu, 2011-08-25 at 17:51 -0500, Jonathan Monette wrote:
> my bad….try www.ci.uchicago.edu/~jonmon/logs/coasters.log
Could you gzip that?
> On Aug 25, 2011, at 5:41 PM, Mihael Hategan wrote:
> > mike at blabla:~/tmp$ wget
> > http://www.ci.uchicago.edu/~jonmon/log/coaster.log
> > --2011-08-25 15:40:31--
> > Resolving www.ci.uchicago.edu... 192.5.86.67
> > Connecting to www.ci.uchicago.edu|192.5.86.67|:80... connected.
> > HTTP request sent, awaiting response... 404 Not Found
> > 2011-08-25 15:40:32 ERROR 404: Not Found.
> > On Thu, 2011-08-25 at 16:43 -0500, Jonathan Monette wrote:
> >> Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
> >> On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
> >>> Can you post the coaster log on the remote machine?
> >>> On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
> >>>> Ok.  I will check my configuration.  I don't see very helpful messages
> >>>> in the log file but I will give a closer look.  More information to
> >>>> follow.
> >>>> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> >>>>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
> >>>>> do not see such messages.
> >>>>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
> >>>>> <jonmon at mcs.anl.gov> wrote:
> >>>>>       This also seems to be happening in trunk.  Is anyone seeing
> >>>>>       this issue with there code?
> >>>>>       On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> >>>>>> I started a run of my SwiftMontage work and all the jobs
> >>>>>       keep failing.  No progress is being made and the swift
> >>>>>       stdout will have the line "failed but can retry: 'some
> >>>>>       number'".  The log is located at
> >>>>>       www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
> >>>>>> _______________________________________________
> >>>>>> Swift-devel mailing list
> >>>>>> Swift-devel at ci.uchicago.edu
> >>>>>       https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >>>>> Ketan
