[Swift-devel] Swift jobs failing
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 16:43:23 CDT 2011
Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
www.ci.uchicago.edu/~jonmon/log/coaster.log
On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
> Can you post the coaster log on the remote machine?
> On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
>> Ok.  I will check my configuration.  I don't see very helpful messages
>> in the log file but I will give a closer look.  More information to
>> follow.
>> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
>>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
>>> do not see such messages.
>>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
>>> <jonmon at mcs.anl.gov> wrote:
>>>        This also seems to be happening in trunk.  Is anyone seeing
>>>        this issue with there code?
>>>        On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
>>>> I started a run of my SwiftMontage work and all the jobs
>>>        keep failing.  No progress is being made and the swift
>>>        stdout will have the line "failed but can retry: 'some
>>>        number'".  The log is located at
>>>        www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>        https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Ketan
