[Swift-devel] Swift jobs failing
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 17:41:28 CDT 2011
mike at blabla:~/tmp$ wget
http://www.ci.uchicago.edu/~jonmon/log/coaster.log
--2011-08-25 15:40:31--
Resolving www.ci.uchicago.edu... 192.5.86.67
Connecting to www.ci.uchicago.edu|192.5.86.67|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2011-08-25 15:40:32 ERROR 404: Not Found.
On Thu, 2011-08-25 at 16:43 -0500, Jonathan Monette wrote:
> Here is the link.  The log is very long(has entries from 2010) but the log toward the bottom does mention that it could not register the coaster service.
> On Aug 25, 2011, at 2:11 PM, Mihael Hategan wrote:
> > Can you post the coaster log on the remote machine?
> > On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
> >> Ok.  I will check my configuration.  I don't see very helpful messages
> >> in the log file but I will give a closer look.  More information to
> >> follow.
> >> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> >>> I am using 0.93 from Communicado to OSG using persistent-coasters. I
> >>> do not see such messages.
> >>> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
> >>> <jonmon at mcs.anl.gov> wrote:
> >>>        This also seems to be happening in trunk.  Is anyone seeing
> >>>        this issue with there code?
> >>>        On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> >>>> I started a run of my SwiftMontage work and all the jobs
> >>>        keep failing.  No progress is being made and the swift
> >>>        stdout will have the line "failed but can retry: 'some
> >>>        number'".  The log is located at
> >>>        www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>        https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >>> Ketan
