[Swift-devel] Swift jobs failing
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 14:11:28 CDT 2011
Can you post the coaster log on the remote machine?
On Thu, 2011-08-25 at 14:07 -0500, Jonathan Monette wrote:
> Ok.  I will check my configuration.  I don't see very helpful messages
> in the log file but I will give a closer look.  More information to
> follow.
> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> > I am using 0.93 from Communicado to OSG using persistent-coasters. I
> > do not see such messages.
> > On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette
> > <jonmon at mcs.anl.gov> wrote:
> >         This also seems to be happening in trunk.  Is anyone seeing
> >         this issue with there code?
> >         On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> >         > I started a run of my SwiftMontage work and all the jobs
> >         keep failing.  No progress is being made and the swift
> >         stdout will have the line "failed but can retry: 'some
> >         number'".  The log is located at
> >         www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
> >         > _______________________________________________
> >         > Swift-devel mailing list
> >         > Swift-devel at ci.uchicago.edu
> >         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Ketan
