[Swift-devel] Swift jobs failing
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Aug 25 14:11:23 CDT 2011
I see this message near the only application_exception that appears in the
log:
Service does not appear to be registered with this manager
Seems to be the coasters service not properly starting. Could this be the
cause?
On Thu, Aug 25, 2011 at 2:07 PM, Jonathan Monette <jonmon at mcs.anl.gov>wrote:
> Ok.  I will check my configuration.  I don't see very helpful messages in
> the log file but I will give a closer look.  More information to follow.
> On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> I am using 0.93 from Communicado to OSG using persistent-coasters. I do not
> see such messages.
> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette <jonmon at mcs.anl.gov>wrote:
>> This also seems to be happening in trunk.  Is anyone seeing this issue
>> with there code?
>> On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
>> > I started a run of my SwiftMontage work and all the jobs keep failing.
>>  No progress is being made and the swift stdout will have the line "failed
>> but can retry: 'some number'".  The log is located at
>> www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.
>>  This is with the most recent version of 0.93.
>> > _______________________________________________
>> > Swift-devel mailing list
>> > Swift-devel at ci.uchicago.edu
>> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110825/c729c394/attachment.html>
