[Swift-devel] Swift jobs failing
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 14:07:37 CDT 2011
Ok.  I will check my configuration.  I don't see very helpful messages in the log file but I will give a closer look.  More information to follow.
On Aug 25, 2011, at 2:05 PM, Ketan Maheshwari wrote:
> I am using 0.93 from Communicado to OSG using persistent-coasters. I do not see such messages.
> On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette <jonmon at mcs.anl.gov> wrote:
> This also seems to be happening in trunk.  Is anyone seeing this issue with there code?
> On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> > I started a run of my SwiftMontage work and all the jobs keep failing.  No progress is being made and the swift stdout will have the line "failed but can retry: 'some number'".  The log is located at www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This is with the most recent version of 0.93.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110825/64172918/attachment.html>
