[Swift-devel] Swift jobs failing
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Aug 25 14:05:36 CDT 2011
I am using 0.93 from Communicado to OSG using persistent-coasters. I do not
see such messages.
On Thu, Aug 25, 2011 at 1:42 PM, Jonathan Monette <jonmon at mcs.anl.gov>wrote:
> This also seems to be happening in trunk.  Is anyone seeing this issue with
> there code?
> On Aug 25, 2011, at 12:44 PM, Jonathan Monette wrote:
> > I started a run of my SwiftMontage work and all the jobs keep failing.
>  No progress is being made and the swift stdout will have the line "failed
> but can retry: 'some number'".  The log is located at
> www.ci.uchicago.edu/~jonmon/logs/montage-20110825-1232-y104fa88.log.  This
> is with the most recent version of 0.93.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110825/e6e6f411/attachment.html>
