[Swift-devel] Index out of bounds
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 18 23:14:30 CDT 2011
Ok.  The log is at
www.ci.uchicago.edu/~jonmon/logs/montage-1.log
On Aug 18, 2011, at 5:56 PM, Mihael Hategan wrote:
> It's probably a good idea to post the stack trace of that exception now
> rather than later.
> On Thu, 2011-08-18 at 13:09 -0500, Jonathan Monette wrote:
>> Hello,
>>  I was running 0.93 with one a relatively small run, a 350 task run.
>> The run failed on one of the final tasks. I checked the log file and
>> saw some index out of bounds errors. I tried with a smaller run and
>> didn't see the error.
>> This run was using beagle, pads, and communicado. I was also using
>> cdm. I will post the log in a bit. I am seeing if I cam replicate it
>> without using cdm and with a smaller site pool.
