[Swift-devel] Index out of bounds
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Aug 19 14:03:55 CDT 2011
Hmm. So I can't see how this manages to happen.
I added some checks and debugging statements. Can you update, set log
level of org.globus.cog.abstraction.impl.file.local to DEBUG, re-run and
then post the log when the exception pops up?
Mihael
On Thu, 2011-08-18 at 23:14 -0500, Jonathan Monette wrote:
> Ok.  The log is at
> www.ci.uchicago.edu/~jonmon/logs/montage-1.log
> On Aug 18, 2011, at 5:56 PM, Mihael Hategan wrote:
> > It's probably a good idea to post the stack trace of that exception now
> > rather than later.
> > On Thu, 2011-08-18 at 13:09 -0500, Jonathan Monette wrote:
> >> Hello,
> >>  I was running 0.93 with one a relatively small run, a 350 task run.
> >> The run failed on one of the final tasks. I checked the log file and
> >> saw some index out of bounds errors. I tried with a smaller run and
> >> didn't see the error.
> >> This run was using beagle, pads, and communicado. I was also using
> >> cdm. I will post the log in a bit. I am seeing if I cam replicate it
> >> without using cdm and with a smaller site pool.
