[Swift-devel] Index out of bounds
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 18 17:56:28 CDT 2011
It's probably a good idea to post the stack trace of that exception now
rather than later.
On Thu, 2011-08-18 at 13:09 -0500, Jonathan Monette wrote:
> Hello,
>   I was running 0.93 with one a relatively small run, a 350 task run.
> The run failed on one of the final tasks. I checked the log file and
> saw some index out of bounds errors. I tried with a smaller run and
> didn't see the error.
> This run was using beagle, pads, and communicado. I was also using
> cdm. I will post the log in a bit. I am seeing if I cam replicate it
> without using cdm and with a smaller site pool.
