[Swift-devel] ssh:pbs to beagle
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 28 10:27:23 CDT 2011
Ketan, please file and fix a bugzilla ticket to add to the end of the message:
  > 1. The application "cat" is not available in your tc.data catalog
the text "...at any site/pool in your sites file."
Would that have made it clear to you what the problem was?
- Mike
----- Original Message -----
> The pool name in your sites file is pads-remote-pbs-coasters-ssh but
> you used pbs in your tc.data.
> - Mike
> > Hello,
> > Some context:
> > I am trying to submit a big run on Beagle using swift + coasters.
> > However, a previous run is already underway on beagle. So, there are
> > two difficulties running a new run from its login node:
> > 1. Running another swift from the same jvm will result in chaos on
> > the
> > logs (As far as I know, please correct me if this is not the case
> > anymore)
> > 2. Login node is already under load because of my running previous
> > big
> > run.
> > /context
> > So, I am now trying to submit this big run from a remote host
> > (bridled). I know this has been done on PADS using ssh:pbs, provider
> > coaster. I tried the similar approach on a trial swift script but
> > getting error.
> > Following is the error message:
> > [ketan at bridled catsn.works]$ swift -config cf -tc.file tc
> > -sites.file
> > beagle-coaster-ssh-pbs.xml catsn.swift -n=1
> > Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog
> > modified
> > locally)
> > RunID: 20110428-1002-c8rvqhe6
> > Progress:
> > Caused by: org.globus.cog.karajan.scheduler.NoSuchResourceException
> > Final status: Failed:1
> > The following errors have occurred:
> > Attached are my .swift, sites.xml and tc.data files.
> > Could someone indicate if what I am doing is doable and if so how
> > can
> > I correctly configure my sites and tc setup.
> > Thanks.
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
