[Swift-devel] ssh:pbs to beagle
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 28 10:20:14 CDT 2011
The pool name in your sites file is pads-remote-pbs-coasters-ssh but you used pbs in your tc.data.
- Mike
----- Original Message -----
> Hello,
> Some context:
> I am trying to submit a big run on Beagle using swift + coasters.
> However, a previous run is already underway on beagle. So, there are
> two difficulties running a new run from its login node:
> 1. Running another swift from the same jvm will result in chaos on the
> logs (As far as I know, please correct me if this is not the case
> anymore)
> 2. Login node is already under load because of my running previous big
> run.
> /context
> So, I am now trying to submit this big run from a remote host
> (bridled). I know this has been done on PADS using ssh:pbs, provider
> coaster. I tried the similar approach on a trial swift script but
> getting error.
> Following is the error message:
> [ketan at bridled catsn.works]$ swift -config cf -tc.file tc -sites.file
> beagle-coaster-ssh-pbs.xml catsn.swift -n=1
> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
> locally)
> RunID: 20110428-1002-c8rvqhe6
> Progress:
> The application "cat" is not available in your tc.data catalog
> Caused by: org.globus.cog.karajan.scheduler.NoSuchResourceException
> Final status: Failed:1
> The following errors have occurred:
> 1. The application "cat" is not available in your tc.data catalog
> Attached are my .swift, sites.xml and tc.data files.
> Could someone indicate if what I am doing is doable and if so how can
> I correctly configure my sites and tc setup.
> Thanks.
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
