[Swift-devel] ssh:pbs to beagle
Ketan Maheshwari ketancmaheshwari at gmail.com
Thu Apr 28 10:14:30 CDT 2011
Hello,
Some context:
I am trying to submit a big run on Beagle using swift + coasters. However, a previous run is already underway on beagle. So, there are two difficulties running a new run from its login node:
1. Running another swift from the same jvm will result in chaos on the logs (As far as I know, please correct me if this is not the case anymore)
2. Login node is already under load because of my running previous big run.
/context
So, I am now trying to submit this big run from a remote host (bridled). I know this has been done on PADS using ssh:pbs, provider coaster. I tried the similar approach on a trial swift script but getting error.
Following is the error message:
[ketan at bridled catsn.works]$ swift -config cf -tc.file tc -sites.file beagle-coaster-ssh-pbs.xml catsn.swift -n=1
Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified locally)
RunID: 20110428-1002-c8rvqhe6
Progress:
The application "cat" is not available in your tc.data catalog
Caused by: org.globus.cog.karajan.scheduler.NoSuchResourceException
Final status:  Failed:1
The following errors have occurred:
1. The application "cat" is not available in your tc.data catalog
Attached are my .swift, sites.xml and tc.data files.
Could someone indicate if what I am doing is doable and if so how can I correctly configure my sites and tc setup.
Thanks.
Ketan
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110428/9d474bd5/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110428/9d474bd5/attachment-0001.obj>
Type: application/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110428/9d474bd5/attachment.xml>
