[Swift-devel] trunk 4322 cog 3095 build error
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Fri Apr  8 15:39:10 CDT 2011
it now builds.
Thanks!
-allan
2011/4/8 Mihael Hategan <hategan at mcs.anl.gov>:
> My bad. Try r3096.
> On Fri, 2011-04-08 at 15:25 -0500, Allan Espinosa wrote:
>> delete.dependency.log.1:
>>      [echo] [provider-coaster]: DIST
>>      [echo] [provider-coaster]: JARCOPY
>> delete.jar:
>>      [echo] [provider-coaster]: DELETE.JAR (cog-provider-coaster-0.3.jar)
>> compile:
>>      [echo] [provider-coaster]: COMPILE
>>     [mkdir] Created dir:
>> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build
>>     [javac] Compiling 126 source files to
>>     [javac] /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java:172:
>> cannot find symbol
>>     [javac] symbol  : method getLocalService()
>>     [javac] location: class
>> org.globus.cog.abstraction.coaster.service.CoasterPersistentService
>>     [javac]         writePort(s.getLocalService().getPort(), localPortFile);
>>     [javac]                    ^
>>     [javac] Note:
>> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java
>> uses or overrides a deprecated API.
>>     [javac] Note: Recompile with -Xlint:deprecation for details.
>>     [javac] Note: Some input files use unchecked or unsafe operations.
>>     [javac] Note: Recompile with -Xlint:unchecked for details.
>>     [javac] 1 error
>> BUILD FAILED
>> /autonfs/home/aespinosa/swift/cogkit/modules/swift/build.xml:73: The
>> following error occurred while executing this line:
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:444: The following
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:79: The following
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:52: The following
>> /autonfs/home/aespinosa/swift/cogkit/modules/swift/dependencies.xml:13:
>> The following error occurred while executing this line:
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:163: The following
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:168: The following
>> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build.xml:59:
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:465: The following
>> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:228: Compile failed;
>> see the compiler error output for details.
>> Total time: 38 seconds
