[Swift-devel] trunk 4322 cog 3095 build error
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Apr  8 15:28:41 CDT 2011
My bad. Try r3096.
On Fri, 2011-04-08 at 15:25 -0500, Allan Espinosa wrote:
> delete.dependency.log.1:
>      [echo] [provider-coaster]: DIST
>      [echo] [provider-coaster]: JARCOPY
> delete.jar:
>      [echo] [provider-coaster]: DELETE.JAR (cog-provider-coaster-0.3.jar)
> compile:
>      [echo] [provider-coaster]: COMPILE
>     [mkdir] Created dir:
> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build
>     [javac] Compiling 126 source files to
>     [javac] /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java:172:
> cannot find symbol
>     [javac] symbol  : method getLocalService()
>     [javac] location: class
> org.globus.cog.abstraction.coaster.service.CoasterPersistentService
>     [javac]         writePort(s.getLocalService().getPort(), localPortFile);
>     [javac]                    ^
>     [javac] Note:
> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java
> uses or overrides a deprecated API.
>     [javac] Note: Recompile with -Xlint:deprecation for details.
>     [javac] Note: Some input files use unchecked or unsafe operations.
>     [javac] Note: Recompile with -Xlint:unchecked for details.
>     [javac] 1 error
> BUILD FAILED
> /autonfs/home/aespinosa/swift/cogkit/modules/swift/build.xml:73: The
> following error occurred while executing this line:
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:444: The following
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:79: The following
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:52: The following
> /autonfs/home/aespinosa/swift/cogkit/modules/swift/dependencies.xml:13:
> The following error occurred while executing this line:
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:163: The following
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:168: The following
> /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build.xml:59:
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:465: The following
> /autonfs/home/aespinosa/swift/cogkit/mbuild.xml:228: Compile failed;
> see the compiler error output for details.
> Total time: 38 seconds
