[Swift-devel] trunk 4322 cog 3095 build error
Allan Espinosa aespinosa at cs.uchicago.edu
Fri Apr 8 15:25:08 CDT 2011
delete.dependency.log.1:
     [echo] [provider-coaster]: DIST
     [echo] [provider-coaster]: JARCOPY
delete.jar:
     [echo] [provider-coaster]: DELETE.JAR (cog-provider-coaster-0.3.jar)
compile:
     [echo] [provider-coaster]: COMPILE
    [mkdir] Created dir:
/autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build
    [javac] Compiling 126 source files to
    [javac] /autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterPersistentService.java:172:
cannot find symbol
    [javac] symbol  : method getLocalService()
    [javac] location: class
org.globus.cog.abstraction.coaster.service.CoasterPersistentService
    [javac]         writePort(s.getLocalService().getPort(), localPortFile);
    [javac]                    ^
    [javac] Note:
/autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java
uses or overrides a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] Note: Some input files use unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 1 error
BUILD FAILED
/autonfs/home/aespinosa/swift/cogkit/modules/swift/build.xml:73: The
following error occurred while executing this line:
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:444: The following
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:79: The following
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:52: The following
/autonfs/home/aespinosa/swift/cogkit/modules/swift/dependencies.xml:13:
The following error occurred while executing this line:
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:163: The following
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:168: The following
/autonfs/home/aespinosa/swift/cogkit/modules/provider-coaster/build.xml:59:
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:465: The following
/autonfs/home/aespinosa/swift/cogkit/mbuild.xml:228: Compile failed;
see the compiler error output for details.
Total time: 38 seconds
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
