[Swift-devel] Re: Resume not working in 0.92? Please test.
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Apr  5 16:47:22 CDT 2011
Mike,
I tested resume and it is working indeed:
I tested it on local as well as Beagle and it is working well for the latest 0.92 Cray version.
Unfortunately, I did not preserve the old 0.92 branch on Beagle. If you see resume is worth testing for that branch, I will check it out that too.
The resume test does not exist on current test suite. I will add a test and let you know how it goes.
Ketan
On Apr 5, 2011, at 3:01 PM, Michael Wilde wrote:
> Ketan, to follow up on your mention to me that resume is not working on the latest 0.92 on Beagle, can you do the following:
> Try a simple foreach script (like /home/wilde/swift/lab/catsnsleep) under the old 0.92 Cray version.  Say 10 sleeps throttles 1 at a time on localhost.
> Hit ^c, then try resume. This *should* work.
> Then try same in the fixed 0.92 branch to see if possibly resume is broken there (as it was reported to be in trunk:
>  https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=273
> Then try trunk as well.
> Can you check to see if the current test suite has a resume test?  If so, please try that as well (or instead of the above).  If not, can you add it, and report back to swift-devel what you find on the state of resume?
> - Mike
