[Swift-devel] Resume not working in 0.92? Please test.
Michael Wilde wilde at mcs.anl.gov
Tue Apr 5 15:01:19 CDT 2011
Ketan, to follow up on your mention to me that resume is not working on the latest 0.92 on Beagle, can you do the following:
Try a simple foreach script (like /home/wilde/swift/lab/catsnsleep) under the old 0.92 Cray version.  Say 10 sleeps throttles 1 at a time on localhost.
Hit ^c, then try resume. This *should* work.
Then try same in the fixed 0.92 branch to see if possibly resume is broken there (as it was reported to be in trunk:
  https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=273
Then try trunk as well.
Can you check to see if the current test suite has a resume test?  If so, please try that as well (or instead of the above).  If not, can you add it, and report back to swift-devel what you find on the state of resume?
- Mike
