[Swift-devel] Re: Resume not working in 0.92? Please test.
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Apr  5 17:16:25 CDT 2011
OK, very good, Ketan.  Resume worked for me in the old Cray 0.92 version, so if it works in the current one, then that is great.
So I'm assuming that your original suspicion that resume does not work in the latest 0.92+ branch was erroneous.
Please test trunk as well, which is the code version that Allan filed bug 273 against.
I see in your modftdock writeup that when you document resume you did not give the same arguments to swift as in the initial invocation. Those are needed for correct resume behavior. The resume feature assumes that the resumed run is running in the exact same environment as the run represented in the rlog.
If you need it for reference, the original Cray 0.92 version is in /home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast
(but I see little need to test that rev other than to verify that it exhibits the twice-each bug).
- Mike
----- Original Message -----
> Mike,
> I tested resume and it is working indeed:
> I tested it on local as well as Beagle and it is working well for the
> latest 0.92 Cray version.
> Unfortunately, I did not preserve the old 0.92 branch on Beagle. If
> you see resume is worth testing for that branch, I will check it out
> that too.
> The resume test does not exist on current test suite. I will add a
> test and let you know how it goes.
> Ketan
> On Apr 5, 2011, at 3:01 PM, Michael Wilde wrote:
> > Ketan, to follow up on your mention to me that resume is not working
> > on the latest 0.92 on Beagle, can you do the following:
> > Try a simple foreach script (like /home/wilde/swift/lab/catsnsleep)
> > under the old 0.92 Cray version. Say 10 sleeps throttles 1 at a time
> > on localhost.
> > Hit ^c, then try resume. This *should* work.
> > Then try same in the fixed 0.92 branch to see if possibly resume is
> > broken there (as it was reported to be in trunk:
> >  https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=273
> > Then try trunk as well.
> > Can you check to see if the current test suite has a resume test? If
> > so, please try that as well (or instead of the above). If not, can
> > you add it, and report back to swift-devel what you find on the
> > state of resume?
> > - Mike
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
