[Swift-devel] [Bug 325] New: indicate host gridftp server that	caused the error:
    bugzilla-daemon at mcs.anl.gov
    Tue Apr  5 13:52:38 CDT 2011
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=325
           Summary: indicate host gridftp server that caused the error:
           Product: Swift
           Version: trunk
          Platform: PC
        OS/Version: Linux
            Status: NEW
          Severity: normal
          Priority: P2
         Component: error messages
        AssignedTo: skenny at uchicago.edu
        ReportedBy: aespinosa at cs.uchicago.edu
                CC: swift-devel at ci.uchicago.edu
type file;
app (file o) cat(file i) {
  cat i @stdout=o;
file y<"gsiftp://somehost//filename3">;
file x <"gsiftp://somehost//filename";
x=cat(y);
sites.xml
<config>
  <pool>
  <gridftp url="gsiftp://anotherhost"/>
  <workdirectory>/someworkdir</workdirectory>
  </pool>
</config>
When something goes wrong with either hosts 'somehost' and 'another' host, logs
and error messages only report this:
Caused by: org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
Error communicating with the GridFTP server
Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
org.globus.cog.abstraction.impl.file.IrrecoverableResourceException: Error
Caused by: java.net.ConnectException: Connection refused
Final status:  Failed:4  Finished in previous run:11
This is manageable for single remote resources. but with more pools (hence
gridftp endpoints), this is getting harder to debug
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug.
