[Swift-devel] Re: Can you test 0.92 branch for 0.92.1 release?
    Jonathan Monette
    jon.monette at gmail.com
    Tue Apr  5 14:37:09 CDT 2011
Yes. That is the one I remember seeing.  That is much easier than what my
Montage scripts are doing.
On Tue, Apr 5, 2011 at 2:33 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Yes, I had posted variations of the following to the list:
> zz3.swift:
> int arr[];
> arr[0]=1;
> arr[1]=2;
> foreach a in arr {
>  trace("for", a);
> zz6.swift:
> int arr[];
> foreach a,i in [0:9] {
>  arr[i] = i;
> trace("arr",arr);
> foreach a,i in arr {
>  trace("for", a,i);
> com$
> PATH=/home/wilde/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/:$PATH
> com$ which swift
> ~/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/swift
> com$ cd swift/lab
> com$ swift zz3.swift
> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
> locally)
> RunID: 20110404-1344-j98f22id
> Progress:
> SwiftScript trace: for, 2
> SwiftScript trace: for, 1
> Final status:
> com$ PATH=~/swift/rev/swift-0.92/bin:$PATH
> Swift svn swift-r4157 cog-r3056
> RunID: 20110404-1344-ensm4te8
> Progress:
> Final status:
> com$ swift zz6.swift
> RunID: 20110404-1344-i7y6q1i1
> Progress:
> SwiftScript trace: arr, arr.$[]/10
> SwiftScript trace: for, 3, 3
> SwiftScript trace: for, 2, 2
> SwiftScript trace: for, 4, 4
> SwiftScript trace: for, 5, 5
> SwiftScript trace: for, 9, 9
> SwiftScript trace: for, 1, 1
> SwiftScript trace: for, 7, 7
> SwiftScript trace: for, 6, 6
> SwiftScript trace: for, 0, 0
> SwiftScript trace: for, 8, 8
> Final status:
> com$
> > The script I posted might be too complex to use to replicate the twice
> > each bug. However, didn't Mike post a simple loop script that was
> > looping twice when the bug was initially found?
> > On Tue, Apr 5, 2011 at 2:17 PM, Ketan Maheshwari <
> > ketancmaheshwari at gmail.com > wrote:
> > Sarah,
> > I do not have the test you are asking for yet. I am looking at the
> > test suite and will start on Beagle soon.
> > Ketan
> > On Apr 5, 2011, at 2:13 PM, Sarah Kenny wrote:
> > i'm currently working on a swift script to replicate the bug for .92
> > which i will then commit to svn in the test suite. if you mike, or
> > ketan already have this let me know (i'm trying to hack the script jon
> > posted to the list) and i'll use yours...david said he doesn't have
> > one.
> > as i said, my plan was to test on ranger, abe and a couple of (uci)
> > local workstations.
> > ~sk
> > On Tue, Apr 5, 2011 at 12:10 PM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > David, Sarah, Ketan,
> > Can you all report back to the devel list on your progress on testing
> > the release? Ie, what systems are you testing, and which of those
> > tests are complete? When will the rest be done, and hence when are we
> > ready to tag and release the fix?
> > I asked who will create the test to confirm that the twice-each bug is
> > fixed, but no one responded. Which of the three of you feel you know
> > how to do this? Is this being tested in your new tests?
> > Ketan tells me that in the 0.92+ interim release I made for Beagle it
> > looks like the resume feature is not working. I was aware that such a
> > bug was reported in trunk, but in the original 0.92 Cray version
> > (under /home/wilde/swift/rev) resume *was* working. Does the test
> > suite test the resume feature at the moment?
> > Lastly, who will tag and upload the new release, remove or change the
> > red warning in the download page, and announce 0.92.1 on swift-user?
> > - Mike
> > > Thanks, David. Please cc all discussion of this sort to swift-devel.
> > > I assume SVN is working for you now? (It was working for me, from
> > > communicadao, around 9AM this morning).
> > > - Mike
> > > > It appears that there may be a problem with svn.ci.uchicago.edu .
> > > > I
> > > > am
> > > > unable to connect from an SVN client or through the web interface
> > > > both attempts just hang indefinitely. I have sent an email to
> > > > support
> > > > (ticket 12539), but just wanted to give you guys a heads up that
> > > > there
> > > > may be an issue there. I will try to run the tests again in the
> > > > morning.
> > > > David
> > > > On Mon, Apr 4, 2011 at 2:42 PM, Michael Wilde < wilde at mcs.anl.gov
> > > > wrote:
> > > > David, Sarah,
> > > > How quickly could you re-divide the Swift site test plan between
> > > > you
> > > > and confirm back to swift-devel that we are ready to tag and
> > > > release
> > > > the branch as 0.92.1?
> > > > Before we do that, you need to add a test to the test suite that
> > > > can
> > > > replicate the twice-each bug and verify that its detected in 0.92
> > > > and
> > > > corrected in 0.92.1
> > > > Can you possibly do this by noon tomorrow?
> > > > Can you post a checklist of tests with names of who's going to run
> > > > them?
> > > > Depending on what you can commit to, I will see if I, Ketan,
> > > > and/or
> > > > Justin can help take various sites as well. I feel we really need
> > > > to
> > > > do this quickly so we have a stable trusted release out there.
> > > > Thanks,
> > > > Mike
> > > > Michael Wilde
> > > > Computation Institute, University of Chicago
> > > > Mathematics and Computer Science Division
> > > > Argonne National Laboratory
> > > Michael Wilde
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Michael Wilde
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
> Michael Wilde
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110405/9c08f10d/attachment.html>
