[Swift-devel] Re: Can you test 0.92 branch for 0.92.1 release?
    Sarah Kenny
    skenny at uchicago.edu
    Tue Apr  5 14:38:50 CDT 2011
got it thanks...to be clear i wasn't going to try to run the whole montage
scripit :P but this is easier than extracting the faulty loop :)
On Tue, Apr 5, 2011 at 12:37 PM, Jonathan Monette <jon.monette at gmail.com>wrote:
> Yes. That is the one I remember seeing.  That is much easier than what my
> Montage scripts are doing.
> On Tue, Apr 5, 2011 at 2:33 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Yes, I had posted variations of the following to the list:
>> zz3.swift:
>> int arr[];
>> arr[0]=1;
>> arr[1]=2;
>> foreach a in arr {
>>  trace("for", a);
>> zz6.swift:
>> int arr[];
>> foreach a,i in [0:9] {
>>  arr[i] = i;
>> trace("arr",arr);
>> foreach a,i in arr {
>>  trace("for", a,i);
>> com$
>> PATH=/home/wilde/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/:$PATH
>> com$ which swift
>> ~/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/swift
>> com$ cd swift/lab
>> com$ swift zz3.swift
>> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
>> locally)
>> RunID: 20110404-1344-j98f22id
>> Progress:
>> SwiftScript trace: for, 2
>> SwiftScript trace: for, 1
>> Final status:
>> com$ PATH=~/swift/rev/swift-0.92/bin:$PATH
>> Swift svn swift-r4157 cog-r3056
>> RunID: 20110404-1344-ensm4te8
>> Progress:
>> Final status:
>> com$ swift zz6.swift
>> RunID: 20110404-1344-i7y6q1i1
>> Progress:
>> SwiftScript trace: arr, arr.$[]/10
>> SwiftScript trace: for, 3, 3
>> SwiftScript trace: for, 2, 2
>> SwiftScript trace: for, 4, 4
>> SwiftScript trace: for, 5, 5
>> SwiftScript trace: for, 9, 9
>> SwiftScript trace: for, 1, 1
>> SwiftScript trace: for, 7, 7
>> SwiftScript trace: for, 6, 6
>> SwiftScript trace: for, 0, 0
>> SwiftScript trace: for, 8, 8
>> Final status:
>> com$
>> ----- Original Message -----
>> > The script I posted might be too complex to use to replicate the twice
>> > each bug. However, didn't Mike post a simple loop script that was
>> > looping twice when the bug was initially found?
>> > On Tue, Apr 5, 2011 at 2:17 PM, Ketan Maheshwari <
>> > ketancmaheshwari at gmail.com > wrote:
>> > Sarah,
>> > I do not have the test you are asking for yet. I am looking at the
>> > test suite and will start on Beagle soon.
>> > Ketan
>> > On Apr 5, 2011, at 2:13 PM, Sarah Kenny wrote:
>> > i'm currently working on a swift script to replicate the bug for .92
>> > which i will then commit to svn in the test suite. if you mike, or
>> > ketan already have this let me know (i'm trying to hack the script jon
>> > posted to the list) and i'll use yours...david said he doesn't have
>> > one.
>> > as i said, my plan was to test on ranger, abe and a couple of (uci)
>> > local workstations.
>> > ~sk
>> > On Tue, Apr 5, 2011 at 12:10 PM, Michael Wilde < wilde at mcs.anl.gov >
>> > wrote:
>> > David, Sarah, Ketan,
>> > Can you all report back to the devel list on your progress on testing
>> > the release? Ie, what systems are you testing, and which of those
>> > tests are complete? When will the rest be done, and hence when are we
>> > ready to tag and release the fix?
>> > I asked who will create the test to confirm that the twice-each bug is
>> > fixed, but no one responded. Which of the three of you feel you know
>> > how to do this? Is this being tested in your new tests?
>> > Ketan tells me that in the 0.92+ interim release I made for Beagle it
>> > looks like the resume feature is not working. I was aware that such a
>> > bug was reported in trunk, but in the original 0.92 Cray version
>> > (under /home/wilde/swift/rev) resume *was* working. Does the test
>> > suite test the resume feature at the moment?
>> > Lastly, who will tag and upload the new release, remove or change the
>> > red warning in the download page, and announce 0.92.1 on swift-user?
>> > - Mike
>> > > Thanks, David. Please cc all discussion of this sort to swift-devel.
>> > > I assume SVN is working for you now? (It was working for me, from
>> > > communicadao, around 9AM this morning).
>> > > - Mike
>> > > > It appears that there may be a problem with svn.ci.uchicago.edu .
>> > > > I
>> > > > am
>> > > > unable to connect from an SVN client or through the web interface
>> > > > both attempts just hang indefinitely. I have sent an email to
>> > > > support
>> > > > (ticket 12539), but just wanted to give you guys a heads up that
>> > > > there
>> > > > may be an issue there. I will try to run the tests again in the
>> > > > morning.
>> > > > David
>> > > > On Mon, Apr 4, 2011 at 2:42 PM, Michael Wilde < wilde at mcs.anl.gov
>> > > > wrote:
>> > > > David, Sarah,
>> > > > How quickly could you re-divide the Swift site test plan between
>> > > > you
>> > > > and confirm back to swift-devel that we are ready to tag and
>> > > > release
>> > > > the branch as 0.92.1?
>> > > > Before we do that, you need to add a test to the test suite that
>> > > > can
>> > > > replicate the twice-each bug and verify that its detected in 0.92
>> > > > and
>> > > > corrected in 0.92.1
>> > > > Can you possibly do this by noon tomorrow?
>> > > > Can you post a checklist of tests with names of who's going to run
>> > > > them?
>> > > > Depending on what you can commit to, I will see if I, Ketan,
>> > > > and/or
>> > > > Justin can help take various sites as well. I feel we really need
>> > > > to
>> > > > do this quickly so we have a stable trusted release out there.
>> > > > Thanks,
>> > > > Mike
>> > > > Michael Wilde
>> > > > Computation Institute, University of Chicago
>> > > > Mathematics and Computer Science Division
>> > > > Argonne National Laboratory
>> > > Michael Wilde
>> > > _______________________________________________
>> > > Swift-devel mailing list
>> > > Swift-devel at ci.uchicago.edu
>> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> > Michael Wilde
>> > Any intelligent fool can make things bigger and more complex... It
>> > takes a touch of genius - and a lot of courage to move in the opposite
>> > direction.
>> > - Albert Einstein
>> Michael Wilde
> Any intelligent fool can make things bigger and more complex... It takes a
> touch of genius - and a lot of courage to move in the opposite direction.
> - Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110405/c2ccfcbb/attachment.html>
