[Swift-devel] Re: Can you test 0.92 branch for 0.92.1 release?
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Apr  5 14:33:42 CDT 2011
Yes, I had posted variations of the following to the list:
zz3.swift:
int arr[];
arr[0]=1;
arr[1]=2;
foreach a in arr {
  trace("for", a);
zz6.swift:
int arr[];
foreach a,i in [0:9] {
  arr[i] = i;
trace("arr",arr);
foreach a,i in arr {
  trace("for", a,i);
com$ PATH=/home/wilde/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/:$PATH
com$ which swift
~/swift/src/0.92/cog/modules/swift/dist/swift-svn/bin/swift
com$ cd swift/lab
com$ swift zz3.swift
Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified locally)
RunID: 20110404-1344-j98f22id
Progress:
SwiftScript trace: for, 2
SwiftScript trace: for, 1
Final status:
com$ PATH=~/swift/rev/swift-0.92/bin:$PATH
Swift svn swift-r4157 cog-r3056
RunID: 20110404-1344-ensm4te8
Progress:
Final status:
com$ swift zz6.swift
RunID: 20110404-1344-i7y6q1i1
Progress:
SwiftScript trace: arr, arr.$[]/10
SwiftScript trace: for, 3, 3
SwiftScript trace: for, 2, 2
SwiftScript trace: for, 4, 4
SwiftScript trace: for, 5, 5
SwiftScript trace: for, 9, 9
SwiftScript trace: for, 1, 1
SwiftScript trace: for, 7, 7
SwiftScript trace: for, 6, 6
SwiftScript trace: for, 0, 0
SwiftScript trace: for, 8, 8
Final status:
com$
----- Original Message -----
> The script I posted might be too complex to use to replicate the twice
> each bug. However, didn't Mike post a simple loop script that was
> looping twice when the bug was initially found?
> On Tue, Apr 5, 2011 at 2:17 PM, Ketan Maheshwari <
> ketancmaheshwari at gmail.com > wrote:
> Sarah,
> I do not have the test you are asking for yet. I am looking at the
> test suite and will start on Beagle soon.
> Ketan
> On Apr 5, 2011, at 2:13 PM, Sarah Kenny wrote:
> i'm currently working on a swift script to replicate the bug for .92
> which i will then commit to svn in the test suite. if you mike, or
> ketan already have this let me know (i'm trying to hack the script jon
> posted to the list) and i'll use yours...david said he doesn't have
> one.
> as i said, my plan was to test on ranger, abe and a couple of (uci)
> local workstations.
> ~sk
> On Tue, Apr 5, 2011 at 12:10 PM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> David, Sarah, Ketan,
> Can you all report back to the devel list on your progress on testing
> the release? Ie, what systems are you testing, and which of those
> tests are complete? When will the rest be done, and hence when are we
> ready to tag and release the fix?
> I asked who will create the test to confirm that the twice-each bug is
> fixed, but no one responded. Which of the three of you feel you know
> how to do this? Is this being tested in your new tests?
> Ketan tells me that in the 0.92+ interim release I made for Beagle it
> looks like the resume feature is not working. I was aware that such a
> bug was reported in trunk, but in the original 0.92 Cray version
> (under /home/wilde/swift/rev) resume *was* working. Does the test
> suite test the resume feature at the moment?
> Lastly, who will tag and upload the new release, remove or change the
> red warning in the download page, and announce 0.92.1 on swift-user?
> - Mike
> > Thanks, David. Please cc all discussion of this sort to swift-devel.
> > I assume SVN is working for you now? (It was working for me, from
> > communicadao, around 9AM this morning).
> > - Mike
> > > It appears that there may be a problem with svn.ci.uchicago.edu .
> > > I
> > > am
> > > unable to connect from an SVN client or through the web interface
> > > both attempts just hang indefinitely. I have sent an email to
> > > support
> > > (ticket 12539), but just wanted to give you guys a heads up that
> > > there
> > > may be an issue there. I will try to run the tests again in the
> > > morning.
> > > David
> > > On Mon, Apr 4, 2011 at 2:42 PM, Michael Wilde < wilde at mcs.anl.gov
> > > wrote:
> > > David, Sarah,
> > > How quickly could you re-divide the Swift site test plan between
> > > you
> > > and confirm back to swift-devel that we are ready to tag and
> > > release
> > > the branch as 0.92.1?
> > > Before we do that, you need to add a test to the test suite that
> > > can
> > > replicate the twice-each bug and verify that its detected in 0.92
> > > and
> > > corrected in 0.92.1
> > > Can you possibly do this by noon tomorrow?
> > > Can you post a checklist of tests with names of who's going to run
> > > them?
> > > Depending on what you can commit to, I will see if I, Ketan,
> > > and/or
> > > Justin can help take various sites as well. I feel we really need
> > > to
> > > do this quickly so we have a stable trusted release out there.
> > > Thanks,
> > > Mike
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > Michael Wilde
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
Michael Wilde
