[Swift-devel] duplicated job submission in swift-0.92?
    Jonathan Monette
    jon.monette at gmail.com
    Mon Apr  4 00:04:39 CDT 2011
My small workflow finished without error and was faster than what trunk was
doing(maybe had something to do with the twice foreach loop).  Running my
largest workflow to see what happens.  But seems to be working fine.
On Sun, Apr 3, 2011 at 11:53 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sun, 2011-04-03 at 23:21 -0500, Michael Wilde wrote:
> > Ive tried the failing examples on a fresh checkout of the 0.92 branch,
> and that works now - excellent.
> > Allan and Jon, can you try your scripts on this latest 0.92 from svn?
> > Ive also re-built the 0.92 version with Cray support. That seems to work
> as well.
> > When I updated my 0.92 branch I jumped to: swift-r4252, cog-r3088,
> > which I assume is largely from un-doing the inadvertent post-0.92
> > merge from trunk?
> Yes. Svn revisions are monotonic in time.
> > - Mike
> > ----- Original Message -----
> > > That would be a tag and we'd do it after we test the current code in
> > > the
> > > branch a bit.
> > > On Sun, 2011-04-03 at 13:16 -0500, Michael Wilde wrote:
> > > > Nice - thank you, Mihael! Can you make the branch next? Call it
> > > > 0.92.1 or .2, whatever you think is best practice (I favor 0.92.1
> > > > but have no strong feeling).
> > > > - Mike
> > > > > On Thu, 2011-03-31 at 11:52 -0700, Mihael Hategan wrote:
> > > > > > We decided the following:
> > > > > > - I will revert the changes in the 0.92 branch
> > > > > done
> > > > > > - re-commit bug fixes that were committed after the merge
> > > > > done
> > > > > > - merge the 0.92 branch to trunk
> > > > > done
> > > > > > - fix the problems in trunk
> > > > > and done except the problem was in the branch. I think it was a
> > > > > manual
> > > > > merge of mine gone wrong. Trunk should be clean.
> > > > > We should make a patch release.
> > > > > Mihael
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110404/a3ad873d/attachment.html>
