[Swift-devel] compile error
Jonathan Monette
jon.monette at gmail.com
Sun Apr 3 22:02:02 CDT 2011
That fixed the compile error.
On Sun, Apr 3, 2011 at 9:54 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> Oops, please try again at r4251.
> On Sun, 3 Apr 2011, Jonathan Monette wrote:
> I just tried compiling swift-r4251 and got the following compile errror:
>> compile:
>> [echo] [swift]: COMPILE
>> [mkdir] Created dir:
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build
>> [javac] Compiling 377 source files to
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:578:
>> cannot find symbol
>> [javac] symbol : method getAnyNumOdInputArgs()
>> [javac] location: class org.griphyn.vdl.engine.ProcedureSignature
>> [javac] if (!proc.getAnyNumOdInputArgs() && (call.sizeOfInputArray() <
>> proc.sizeOfInputArray() - noOfOptInArgs ||
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:587:
>> cannot find symbol
>> [javac] symbol : method getAnyNumOdOutputArgs()
>> [javac] if (!proc.getAnyNumOdOutputArgs() && (call.sizeOfOutputArray()
>> != proc.sizeOfOutputArray()))
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:599:
>> cannot find symbol
>> [javac] if (proc.getAnyNumOdInputArgs()) {
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:626:
>> cannot find symbol
>> [javac] if (!proc.getAnyNumOdInputArgs() && noOfMandArgs <
>> proc.sizeOfInputArray() - noOfOptInArgs)
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:667:
>> cannot find symbol
>> [javac] if (proc.getAnyNumOdOutputArgs()) {
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:955:
>> cannot find symbol
>> [javac] if (!funcSignature.getAnyNumOdInputArgs() &&
>> [javac] ^
>> [javac]
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:966:
>> cannot find symbol
>> [javac] if (!funcSignature.getAnyNumOdInputArgs()) {
>> [javac] ^
>> [javac] Note: Some input files use unchecked or unsafe operations.
>> [javac] Note: Recompile with -Xlint:unchecked for details.
>> [javac] 7 errors
>> BUILD FAILED
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build.xml:73:
>> The
>> following error occurred while executing this line:
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:465: The following
>> /autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:228: Compile
>> failed;
>> see the compiler error output for details.
>> I am using javac version 1.6.0_22
> Justin M Wozniak
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110403/df512247/attachment.html>
