[Swift-devel] compile error
Justin M Wozniak wozniak at mcs.anl.gov
Sun Apr 3 21:54:36 CDT 2011
Oops, please try again at r4251.
On Sun, 3 Apr 2011, Jonathan Monette wrote:
> I just tried compiling swift-r4251 and got the following compile errror:
> compile:
>     [echo] [swift]: COMPILE
>    [mkdir] Created dir:
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build
>    [javac] Compiling 377 source files to
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:578:
> cannot find symbol
>    [javac] symbol  : method getAnyNumOdInputArgs()
>    [javac] location: class org.griphyn.vdl.engine.ProcedureSignature
>    [javac] if (!proc.getAnyNumOdInputArgs() && (call.sizeOfInputArray() <
> proc.sizeOfInputArray() - noOfOptInArgs ||
>    [javac]          ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:587:
> cannot find symbol
>    [javac] symbol  : method getAnyNumOdOutputArgs()
>    [javac] if (!proc.getAnyNumOdOutputArgs() && (call.sizeOfOutputArray()
> != proc.sizeOfOutputArray()))
>    [javac]          ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:599:
> cannot find symbol
>    [javac] if (proc.getAnyNumOdInputArgs()) {
>    [javac]         ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:626:
> cannot find symbol
>    [javac] if (!proc.getAnyNumOdInputArgs() && noOfMandArgs <
> proc.sizeOfInputArray() - noOfOptInArgs)
>    [javac]          ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:667:
> cannot find symbol
>    [javac] if (proc.getAnyNumOdOutputArgs()) {
>    [javac]         ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:955:
> cannot find symbol
>    [javac] if (!funcSignature.getAnyNumOdInputArgs() &&
>    [javac]                   ^
>    [javac]
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:966:
> cannot find symbol
>    [javac] if (!funcSignature.getAnyNumOdInputArgs()) {
>    [javac]                   ^
>    [javac] Note: Some input files use unchecked or unsafe operations.
>    [javac] Note: Recompile with -Xlint:unchecked for details.
>    [javac] 7 errors
> BUILD FAILED
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build.xml:73: The
> following error occurred while executing this line:
> /autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:465: The following
> /autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:228: Compile failed;
> see the compiler error output for details.
> I am using javac version 1.6.0_22
Justin M Wozniak
