[Swift-devel] compile error
Jonathan Monette
jon.monette at gmail.com
Sun Apr 3 19:14:32 CDT 2011
I just tried compiling swift-r4251 and got the following compile errror:
compile:
[echo] [swift]: COMPILE
[mkdir] Created dir:
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build
[javac] Compiling 377 source files to
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:578:
cannot find symbol
[javac] symbol : method getAnyNumOdInputArgs()
[javac] location: class org.griphyn.vdl.engine.ProcedureSignature
[javac] if (!proc.getAnyNumOdInputArgs() && (call.sizeOfInputArray() <
proc.sizeOfInputArray() - noOfOptInArgs ||
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:587:
cannot find symbol
[javac] symbol : method getAnyNumOdOutputArgs()
[javac] if (!proc.getAnyNumOdOutputArgs() && (call.sizeOfOutputArray()
!= proc.sizeOfOutputArray()))
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:599:
cannot find symbol
[javac] if (proc.getAnyNumOdInputArgs()) {
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:626:
cannot find symbol
[javac] if (!proc.getAnyNumOdInputArgs() && noOfMandArgs <
proc.sizeOfInputArray() - noOfOptInArgs)
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:667:
cannot find symbol
[javac] if (proc.getAnyNumOdOutputArgs()) {
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:955:
cannot find symbol
[javac] if (!funcSignature.getAnyNumOdInputArgs() &&
[javac] ^
[javac]
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/src/org/griphyn/vdl/engine/Karajan.java:966:
cannot find symbol
[javac] if (!funcSignature.getAnyNumOdInputArgs()) {
[javac] ^
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 7 errors
BUILD FAILED
/autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build.xml:73: The
following error occurred while executing this line:
/autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:465: The following
/autonfs/home/jonmon/Library/Swift/trunk/cog/mbuild.xml:228: Compile failed;
see the compiler error output for details.
I am using javac version 1.6.0_22
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110403/c36cb497/attachment.html>
