[Swift-devel] duplicated job submission in swift-0.92?
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Fri Apr  1 17:33:04 CDT 2011
I found that it appeared between Swift r3835 and r3837.
On Fri, 1 Apr 2011, Michael Wilde wrote:
> And Swift 0.91 works OK - it does *not* exhibit the twice-each bug.
> Justin: when you went backwards down the Swift 0.92 branch on Thursday
> morning, what did you find in terms of where it appeared the bug was
> introduced?
> - Mike
>> I think we mist-spoke: The posted release 0.92 also exhibits the
>> twice-each bug as far as I acn tell.
>> Mihael, Justin: can you test asap to confirm or refute that
>> observation?
>> Thanks,
>> - Mike
>> which swift: ~/swift/rev/swift-0.92/bin/swift
>> com$ swift -version
>> Swift svn swift-r4157 cog-r3056
>> com$ cd ~/swift/lab
>> com$ cat zz3.swift
>> int arr[];
>> arr[0]=1;
>> arr[1]=2;
>> foreach a in arr {
>> trace("for", a);
>> com$ swift zz3.swift
>> RunID: 20110401-1645-yyy87p39
>> Progress:
>> SwiftScript trace: for, 2
>> SwiftScript trace: for, 1
>> Final status:
>> com$
>>> I think both are good as they are.
>>> Would you like me to send it?
>>> Mihael
>>> On Thu, 2011-03-31 at 20:57 -0500, Michael Wilde wrote:
>>>> And I will send this to swift-user:
>>>> "Dear Swift Users,
>>>> On March 29 we discovered that the Release 0.92 branches of the
>>>> Swift and CoG trees were changed after the release and a
>>>> concurrency
>>>> bug was introduced. If you are running Swift from this *source
>>>> code*
>>>> base, please revert back to a known-working release such as the
>>>> 0.92
>>>> binary release if at all possible.
>>>> We're working on restoring the 0.92 SVN branch to the correct
>>>> state
>>>> and will report back to this email list when that is done."
>>>> Anything else to say? Feel free to send this out, adjusted as
>>>> needed, or just tell me what to change and I will.
>>>> - Mike
>>>>> Please check this proposed warning on the Downloads page and let
>>>>> me
>>>>> know if its what we need there:
>>>>> http://www.ci.uchicago.edu/~wilde/swift/downloads/index.php
>>>>> I also fixed the 0.91 typo (but the downloads dont actually work
>>>>> from
>>>>> this test web. I think they will once this is committed and
>>>>> pushed
>>>>> live).
>>>>> - Mike
>>>>>>>>> We decided the following:
>>>>>>>>> - I will revert the changes in the 0.92 branch
>>>>>>>>> - re-commit bug fixes that were committed after the
>>>>>>>>> merge
>>>>>>>>> - merge the 0.92 branch to trunk
>>>>>>>>> - fix the problems in trunk
>>>>>>>> Sounds good. But when and how does the fix get to users?
>>>>>>> The package(s) are fine. Though we should probably also have
>>>>>>> a
>>>>>>> source
>>>>>>> package. The merge was done after the package(s) were
>>>>>>> uploaded
>>>>>>> to
>>>>>>> the
>>>>>>> swift site.
>>>>>> Ah, great!
>>>>>>> This only affects folks who have checked out from SVN the
>>>>>>> 0.92
>>>>>>> branch
>>>>>>> after the merge 9 days (or so) ago.
>>>>>> Hmm - I question that. The release we use, based on 0.92 on
>>>>>> Beagle,
>>>>>> shows the twice-each error, and it was made on Feb 25, about
>>>>>> 35
>>>>>> days
>>>>>> ago. Does this merit clarification?
>>>>>>> We should send an email to the user list once this is fixed.
>>>>>>> We
>>>>>>> may
>>>>>>> also
>>>>>>> want to send an email warning them not to check out from SVN
>>>>>>> but
>>>>>>> download the precompiled package instead.
>>>>>> OK. I cant say that this will reach everyone. Perhaps some
>>>>>> status
>>>>>> notes on the Download page are in order. The 0.91 link there
>>>>>> is
>>>>>> wrong,
>>>>>> so we need to fix that page anyways.
>>>>>>> I am a bit confused though. I would have expected the
>>>>>>> release
>>>>>>> to
>>>>>>> come
>>>>>>> with some announcement of some form.
>>>>>> Agreed. We kept this low profile because we were trying to
>>>>>> coordinate
>>>>>> it with a Web change that we never accomplished. And we've
>>>>>> lost
>>>>>> the
>>>>>> habit of swift-user announcements but got to get back to doing
>>>>>> that.
>>>>>> So, yes.
>>>>>>>> Either create a 0.92.1 release (sounds hard based on
>>>>>>>> above)
>>>>>>>> or create a 0.93 release (in which case should we create
>>>>>>>> the
>>>>>>>> 0.93
>>>>>>>> branch from trunk as soon as this is fixed?)
>>>>>>>> How long to re-test? (Thats a question for Sarah, Justin,
>>>>>>>> and
>>>>>>>> Ketan)
>>>>>>>> Could this include the Cray support mods?
>>>>>>> No! Fixing a problem is not a venue for introducing untested
>>>>>>> things
>>>>>>> into
>>>>>>> a release.
>>>>>> I meant the Cray feature for 0.93 not 0.92.1
>>>>>> Yes, that should be tested.
>>>>>> But its being used pretty heavily.
>>>>>> - Mike
>>>>>>> But it could be discussed separately :)
>>>>>>> Mihael
>>>>>> Michael Wilde
>>>>>> Computation Institute, University of Chicago
>>>>>> Mathematics and Computer Science Division
>>>>>> Argonne National Laboratory
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>>>>> Michael Wilde
>> Michael Wilde
Justin M Wozniak
