[Swift-devel] Re: Memory in Swift
    Jonathan Monette
    jon.monette at gmail.com
    Mon Oct 18 16:46:14 CDT 2010
  jonmon   22946 54.6  1.2 788800 318496 pts/17  Sl+  16:42   0:39 java
-Xmx256M
I am assuming that this means the heap space is 256 Megabytes.  Here is
how I set the SWIFT_HEAP_MAX variable:
<profile key="SWIFT_HEAP_MAX" namespace="env">8192M</profile>
Is this how you would set environment variables in the sites.xml file?
I want to make sure the variable is also set for the worker nodes.
On 10/18/2010 04:36 PM, Justin M Wozniak wrote:
> What do you get if you set it to 8192M?
> On Mon, 18 Oct 2010, Jonathan Monette wrote:
>> I am on PADS.
>>>>    1) What is the maximum value for SWIFT_HEAP_MAX?  Is it the
>>>> maximum memory available on the machine?  If I ask for 8Gb will the
>>>> Java heap space be 8Gb?
>>> In bin/swift, that value is passed directly to the Java VM, so it's
>>> implementation-specific.  What kind of machine are you on?
>>>>    2) Assuming that the above question does not fix my problem,
>>>> what can be done to fix memory problems in Swift?  How should a
>>>> Swift script be programmed to avoid these issues or is how Swift
>>>> handles memory not optimal. I have a set of about 4100 images that
>>>> will be stitched together to form a mosaic.  The size of this set
>>>> is 8.1Gb.  Right now in my sites file I set SWIFT_HEAP_MAX to
>>>> 4096M(4Gb) but I am still getting out of memory errors with the
>>>> Java heap space.  Is Swift just not able to scale up to this size
>>>> of data yet?
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
