[Swift-devel] Re: Memory in Swift
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Oct 18 17:14:52 CDT 2010
Actually, to set SWIFT_HEAP_MAX for Swift you should export it in the
environment in which you run bin/swift . So, in the shell you could do:
SWIFT_HEAP_MAX=8192M swift ...
The namespace env is there to let you set the environment for the remote
user job.
On Mon, 18 Oct 2010, Jonathan Monette wrote:
> jonmon 22946 54.6 1.2 788800 318496 pts/17 Sl+ 16:42 0:39 java
> -Xmx256M
> I am assuming that this means the heap space is 256 Megabytes. Here is how I
> set the SWIFT_HEAP_MAX variable:
> <profile key="SWIFT_HEAP_MAX" namespace="env">8192M</profile>
> Is this how you would set environment variables in the sites.xml file? I
> want to make sure the variable is also set for the worker nodes.
> On 10/18/2010 04:36 PM, Justin M Wozniak wrote:
>> What do you get if you set it to 8192M?
>>> I am on PADS.
>>>>> 1) What is the maximum value for SWIFT_HEAP_MAX? Is it the maximum
>>>>> memory available on the machine? If I ask for 8Gb will the Java heap
>>>>> space be 8Gb?
>>>> In bin/swift, that value is passed directly to the Java VM, so it's
>>>> implementation-specific. What kind of machine are you on?
>>>>> 2) Assuming that the above question does not fix my problem, what can
>>>>> be done to fix memory problems in Swift? How should a Swift script be
>>>>> programmed to avoid these issues or is how Swift handles memory not
>>>>> optimal. I have a set of about 4100 images that will be stitched
>>>>> together to form a mosaic. The size of this set is 8.1Gb. Right now in
>>>>> my sites file I set SWIFT_HEAP_MAX to 4096M(4Gb) but I am still getting
>>>>> out of memory errors with the Java heap space. Is Swift just not able
>>>>> to scale up to this size of data yet?
Justin M Wozniak
