[Swift-devel] Re: Memory in Swift
Justin M Wozniak
wozniak at mcs.anl.gov
Mon Oct 18 16:36:23 CDT 2010
What do you get if you set it to 8192M?
On Mon, 18 Oct 2010, Jonathan Monette wrote:
> I am on PADS.
>>> 1) What is the maximum value for SWIFT_HEAP_MAX? Is it the maximum
>>> memory available on the machine? If I ask for 8Gb will the Java heap
>>> space be 8Gb?
>> In bin/swift, that value is passed directly to the Java VM, so it's
>> implementation-specific. What kind of machine are you on?
>>> 2) Assuming that the above question does not fix my problem, what can
>>> be done to fix memory problems in Swift? How should a Swift script be
>>> programmed to avoid these issues or is how Swift handles memory not
>>> optimal. I have a set of about 4100 images that will be stitched together
>>> to form a mosaic. The size of this set is 8.1Gb. Right now in my sites
>>> file I set SWIFT_HEAP_MAX to 4096M(4Gb) but I am still getting out of
>>> memory errors with the Java heap space. Is Swift just not able to scale
>>> up to this size of data yet?
Justin M Wozniak
