[Swift-devel] Re: Memory in Swift
Jonathan Monette jon.monette at gmail.com
Mon Oct 18 13:19:27 CDT 2010
  I am on PADS.
On 10/18/2010 01:21 PM, Justin M Wozniak wrote:
> On Mon, 18 Oct 2010, Jonathan Monette wrote:
>>    1) What is the maximum value for SWIFT_HEAP_MAX?  Is it the
>> maximum memory available on the machine?  If I ask for 8Gb will the
>> Java heap space be 8Gb?
> In bin/swift, that value is passed directly to the Java VM, so it's
> implementation-specific.  What kind of machine are you on?
>>    2) Assuming that the above question does not fix my problem, what
>> can be done to fix memory problems in Swift?  How should a Swift
>> script be programmed to avoid these issues or is how Swift handles
>> memory not optimal. I have a set of about 4100 images that will be
>> stitched together to form a mosaic.  The size of this set is 8.1Gb.
>> Right now in my sites file I set SWIFT_HEAP_MAX to 4096M(4Gb) but I
>> am still getting out of memory errors with the Java heap space.  Is
>> Swift just not able to scale up to this size of data yet?
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
